This section contains fsck cleanup phase messages in the Oracle Solaris 10 release. In this release, similar messages can be found in the fsck summary phase. See fsck Summary Messages for more information.
Once a file system has been checked, a few cleanup functions are performed. The cleanup phase displays the following status messages.
number-of files, number-of-files used, number-of-files free (number-of frags, number-of blocks, percent fragmentation) |
This message indicates that the file system checked contains number-of files using number-of fragment-sized blocks, and that there are number-of fragment-sized blocks free in the file system. The numbers in parentheses break the free count down into number-of free fragments, number-of free full-sized blocks, and the percent fragmentation.
***** FILE SYSTEM WAS MODIFIED ***** |
This message indicates that the file system was modified by fsck. If this file system is mounted or is the current root (/) file system, reboot. If the file system is mounted, you might need to unmount it and run fsck again; otherwise, the work done by fsck might be undone by the in-core copies of tables.
filename FILE SYSTEM STATE SET TO OKAY |
This message indicates that file system filename was marked as stable. Use the fsck -m command to determine if the file system needs checking.
filename FILE SYSTEM STATE NOT SET TO OKAY |
This message indicates that file system filename was not marked as stable. Use the fsck -m command to determine if the file system needs checking.
