If you forget the root password and you cannot log into the system, you will have to do the following:
Stop the system by using the keyboard stop sequence.
Oracle Solaris 10: Boot the system from a boot server or an install server, or from a local CD-ROM.
Mount the root (/) file system.
Remove the root password from the /etc/shadow file.
Reboot the system.
Log in and set root's password.
Starting with Solaris 10 1/06 release: On x86 based systems, boot the system in the Solaris failsafe archive.
Reboot the system.
These procedures are fully described in Chapter 12, Booting an Oracle Solaris System (Tasks), in System Administration Guide: Basic Administration.
GRUB based booting is not available on SPARC based systems in this release.
The following examples describe how to recover from a forgotten root password on both SPARC and x86 based systems.
The following example shows how to recover when you forget the root password by booting from the network. This example assumes that the boot server is already available. Be sure to apply a new root password after the system has rebooted.
(Use keyboard abort sequence--Press Stop A keys to stop the system) ok boot net -s # mount /dev/dsk/c0t3d0s0 /a # cd /a/etc # TERM=vt100 # export TERM # vi shadow (Remove root's encrypted password string) # cd / # umount /a # init 6 |
GNU GRUB version 0.95 (637K lower / 3144640K upper memory) +-------------------------------------------------------------------+ | be1 | be1 failsafe | be3 | be3 failsafe | be2 | be2 failfafe +------------------------------------------------------------------+ Use the ^ and v keys to select which entry is highlighted. Press enter to boot the selected OS, 'e' to edit the commands before booting, or 'c' for a command-line. |
Searching for installed OS instances... An out of sync boot archive was detected on /dev/dsk/c0t0d0s0. The boot archive is a cache of files used during boot and should be kept in sync to ensure proper system operation. Do you wish to automatically update this boot archive? [y,n,?] n Searching for installed OS instances... Multiple OS instances were found. To check and mount one of them read-write under /a, select it from the following list. To not mount any, select 'q'. 1 pool10:13292304648356142148 ROOT/be10 2 rpool:14465159259155950256 ROOT/be01 Please select a device to be mounted (q for none) [?,??,q]: 1 mounting /dev/dsk/c0t0d0s0 on /a starting shell. . . . # cd /a/etc # vi shadow (Remove root's encrypted password string) # cd / # umount /a # reboot |
Oracle Solaris 10: The following example shows how to recover when you forget root's password by booting from the network. This example assumes that the boot server is already available. Be sure to apply a new root password after the system has rebooted.
Press any key to reboot. Resetting... . . . Initializing system Please wait... <<< Current Boot Parameters >>> Boot path: /pci@0,0/pci-ide@7,1/ide@0/cmdk@0,0:a Boot args: Type b [file-name] [boot-flags] <ENTER> to boot with options or i <ENTER> to enter boot interpreter or <ENTER> to boot with defaults <<< timeout in 5 seconds >>> Select (b)oot or (i)nterpreter: b -s SunOS Release 5.10 Version amd64-gate-2004-09-30 32-bit Copyright 1983-2004 Sun Microsystems, Inc. All rights reserved. Use is subject to license terms. DEBUG enabled Booting to milestone "milestone/single-user:default". Hostname: venus NIS domain name is example.com Requesting System Maintenance Mode SINGLE USER MODE Root password for system maintenance (control-d to bypass): xxxxxx Entering System Maintenance Mode . . . # mount /dev/dsk/c0t0d0s0 /a . . . # cd /a/etc # vi shadow (Remove root's encrypted password string) # cd / # umount /a # init 6 |
