System Administration Guide: Oracle Solaris Containers-Resource Management and Oracle Solaris Zones
Creating, Revising, and Deleting Non-Global Zone Configurations (Task Map)
Task
Description
For Instructions
Configure a non-global zone.
Use the zonecfg command to create a zone, verify the configuration, and commit the configuration.
You can also use a script to configure and boot multiple zones on your system. You can use the zonecfg command to display a non-global zone's configuration.
Configuring, Verifying, and Committing a Zone, Script to Configure Multiple Zones
Modify a zone configuration.
Use this procedure to modify a resource type in a zone configuration or add a dedicated device to a zone.
Using the zonecfg Command to Modify a Zone Configuration
Revert a zone configuration or delete a zone configuration.
Use the zonecfg command to undo a resource setting made to a zone configuration or to delete a zone configuration.
Using the zonecfg Command to Revert or Remove a Zone Configuration
Delete a zone configuration.
Use the zonecfg command with the delete subcommand to delete a zone configuration from the system.
How to Delete a Zone Configuration
