Solaris Containers: Resource Management and Solaris Zones Developer's Guide
C Code Examples for Accessing exacct Files
This section provides code examples for accessing exacct files.
Example 3–1 Displaying exacct Data for a Designated pid
This example displays a specific pid's exacct data snapshot from the kernel.
  ea_object_t *scratch;
  int unpk_flag = EUP_ALLOC;  /* use the same allocation flag */
                              /* for unpack and free */
  /* Omit return value checking, to keep code samples short */
  bsize = getacct(P_PID, pid, NULL, 0);
  buf = malloc(bsize);
  /* Retrieve exacct object and unpack */
  getacct(P_PID, pid, buf, bsize);
  ea_unpack_object(&scratch, unpk_flag, buf, bsize);
  /* Display the exacct record */
  disp_obj(scratch);
  if (scratch->eo_type == EO_GROUP) {
         disp_group(scratch);
  ea_free_object(scratch, unpk_flag);
Example 3–2 Identifying Individual Tasks During a Kernel Build
This example evaluates kernel builds and displays a string that describes the portion of the source tree being built by this task make. Display the portion of the source being built to aid in the per-source-directory analysis.
The key points for this example include the following:
/* Omit return value checking and error processing */
/* to keep code sample short */
ptid = gettaskid();	/* Save "parent" task-id */
tid = settaskid(getprojid(), TASK_NORMAL);	/* Create new task */
/* Set data for item objects ptskid and cwd */
ea_set_item(&ptskid, EXT_UINT32 | EXC_LOCAL | MY_PTID, &ptid, 0);
ea_set_item(&cwd, EXT_STRING | EXC_LOCAL | MY_CWD, cwdbuf, strlen(cwdbuf));
/* Set grp object and attach ptskid and cwd to grp */
ea_set_group(&grp, EXT_GROUP | EXC_LOCAL |  EXD_GROUP_HEADER);
ea_attach_to_group(&grp, &ptskid);
ea_attach_to_group(&grp, &cwd);
/* Pack the object and put it back into the accounting stream */
ea_buflen = ea_pack_object(&grp, ea_buf, sizeof(ea_buf));
putacct(P_TASKID, tid, ea_buf, ea_buflen, EP_EXACCT_OBJECT);
/* Memory management: free memory allocate in ea_set_item */
ea_free_item(&cwd, EUP_ALLOC);
Example 3–3 Reading and Displaying the Contents of a System exacct File
This example shows how to read and display a system exacct file for a process or a task.
main(int argc, char *argv)
  ea_file_t ef;
  ea_object_t scratch;
  char *fname;
  fname = argv[1];
  ea_open(&ef, fname, NULL,  EO_NO_VALID_HDR, O_RDONLY, 0);
  bzero(&scratch, sizeof (ea_object_t));
  while (ea_get_object(&ef, &scratch)  != -1) {
	     disp_obj(&scratch);
	     if (scratch.eo_type == EO_GROUP)
	         disp_group(&ef, scratch.eo_group.eg_nobjs);
  ea_close(&ef);
struct catalog_item {   /* convert Solaris catalog's type ID */
                        /* to a meaningful string */
	 int	type;
	 char *name;
 } catalog[] = {
	 { EXD_VERSION, 	"version\t" },
	 { EXD_PROC_PID,	"  pid\t" },
 static char *
 catalog_name(int type)
	 int i = 0;
	 while (catalog[i].type != EXD_NONE) {
		 if (catalog[i].type == type)
			 return (catalog[i].name);
		 else
			 i++;
	 return ("unknown\t");
 static void disp_obj(ea_object_t *o)
	 printf("%s\t", catalog_name(o->eo_catalog & 0xffffff));
	 switch(o->eo_catalog & EXT_TYPE_MASK) {
	 case EXT_UINT8:
		 printf(" 8: %u", o->eo_item.ei_uint8);
		 break;
	 case EXT_UINT16:
 static void disp_group(ea_file_t *ef, uint_t nobjs)
	 for (i = 0; i < nobjs; i++) {
		 ea_get_object(ef, &scratch));
             	 disp_obj(&scratch);
                disp_group(ef, scratch.eo_group.eg_nobjs);
