Solaris Containers: Resource Management and Solaris Zones Developer's Guide
Resource Controls Associated With Processes
Resource controls associated with processes include the following:
process.max-address-space
Maximum amount of address space (bytes), as summed over segment sizes, available to this process.
process.max-core-size
Maximum size (bytes) of a core file that is created by this process.
process.max-cpu-time
Maximum CPU time (seconds) available to this process.
process.max-file-descriptor
Maximum file descriptor index that is available to this process.
process.max-file-size
Maximum file offset (bytes) available for writing by this process.
process.max-msg-messages
Maximum number of messages on a message queue. This value is copied from the resource control at msgget() time.
process.max-msg-qbytes
Maximum number (bytes) of messages on a message queue. This value is copied from the resource control at msgget() time.When you set a new project.max-msg-qbytes value, initialization occurs only on the subsequently created values. The new project.max-msg-qbytes value does not effect existing values.
process.max-sem-nsems
Maximum number of semaphores allowed for a semaphore set.
process.max-sem-ops
Maximum number of semaphore operations that are allowed for a semop() call. This value is copied from the resource control at msgget() time.A new project.max-sem-ops value only affects the initialization of subsequently created values and has no effect on existing values.
process.max-port-events
Maximum number of events that are allowed per event port.
