Solaris Containers: Resource Management and Solaris Zones Developer's Guide
Signals Used With Resource Controls
For each threshold value that is placed on a resource control, the following restricted set of signals is available:
SIGBART
Terminate the process.
SIGXRES
Signal generated by resource control facility when the resource control limit is exceeded.
SIGHUP
When carrier drops on an open line, the process group that controls the terminal is sent a hangup signal, SIGHUP.
SIGSTOP
Job control signal. Stop the process. Stop signal not from terminal.
SIGTERM
Terminate the process. Termination signal sent by software.
SIGKILL
Terminate the process. Kill the program.
SIGXFSX
Terminate the process. File size limit exceeded. Available only to resource controls with the RCTL_GLOBAL_FILE_SIZE property.
SIGXCPU
Terminate the process. CPU time limit exceeded. Available only to resource controls with the RCTL_GLOBAL_CPUTIME property. See rctlblk_set_value(3C) for more information.
Other signals might be permitted due to global properties of a specific control.
Note –
Calls to setrctl() with illegal signals fail.
Figure 5–2 Setting Privilege Levels for Signals
setting privilege levels for signals
