Solaris Containers: Resource Management and Solaris Zones Developer's Guide
System Properties
system.bind-default (writable boolean)
If the specified pool is not found in <filename>/etc/project</filename>, bind to pool with the pool.default property set to TRUE.
system.comment (writable string)
User description of system. system.comment is not used by the default pools commands, except when a configuration is initiated by the poolcfg utility. In this case, the system puts an informative message in the system.comment property for that configuration. (writable string)
User name for the configuration.
system.version (read-only integer)
libpool version required to manipulate this configuration.
