Solaris Containers: Resource Management and Solaris Zones Developer's Guide
Ascertain the Number of CPUs in the Resource Pool
sysconf(3C) provides information about the number of CPUs on an entire system. The following example provides the granularity of ascertaining the number of CPUs that are defined in a particular application's pools pset.
The key points for this example include the following:
pool_value_t *pvals[2] = {NULL};  /* pvals[] should be NULL terminated */
/* NOTE: Return value checking/error processing omitted */
/* in all examples for brevity */
conf_loc = pool_dynamic_location();
conf = pool_conf_alloc();
pool_conf_open(conf, conf_loc, PO_RDONLY);
my_pool_name = pool_get_binding(getpid());
my_pool = pool_get_pool(conf, my_pool_name);
pvals[0] = pool_value_alloc();
pvals2[2] = { NULL, NULL };
pool_value_set_name(pvals[0], "type");
pool_value_set_string(pvals[0], "pset");
reslist = pool_query_pool_resources(conf, my_pool, &nelem, pvals);
pool_query_resource_components(conf, reslist[0], &nelem, NULL);
printf("pool %s: %u cpu", my_pool_ name, nelem);
