Solaris Containers: Resource Management and Solaris Zones Developer's Guide
Set pool.comment Property and Add New Property
The following example sets the pool.comment property for the pset. The example also creates a new property in pool.newprop.
The key point for the example includes the following:
pool_set_comment(const char *pool_name, const char *comment)
  pool_t *pool;
  pool_elem_t *pool_elem;
  pool_value_t *pval = pool_value_alloc();
  pool_conf_t  *conf = pool_conf_alloc();
  /* NOTE: need to be root to use PO_RDWR on static configuration file */
  pool_conf_open(conf, pool_static_location(), PO_RDWR);
  pool = pool_get_pool(conf,  pool_name);
  pool_value_set_string(pval, comment);
  pool_elem = pool_to_elem(conf, pool);
  pool_put_property(conf, pool_elem, "pool.comment", pval);
  printf("pool %s: pool.comment set to %s\n:" pool_name, comment);
  /* Now, create a new property, customized to installation site */
  pool_value_set_string(pval, "New String Property");
  pool_put_property(conf, pool_elem, "pool.newprop", pval);
  pool_conf_commit(conf, 0); /* NOTE: use 0 to ensure only */
                             /* static file gets updated */
  /* NOTE: Use "pooladm -c" later, or pool_conf_commit(conf, 1) */
  /* above for changes to the running system */
An alternative way of modifying a pool's comment and adding a new pool property is to use poolcfg(1M).
poolcfg -c 'modify pool pool-name (string pool.comment = "cmt-string")'
poolcfg -c 'modify pool pool-name (string pool.newprop =
                                   "New String Property")'
