The following table identifies the procedures that are required to manage diskless clients.
Task |
Description |
For Instructions |
1. (Optional) Enable Solaris Management Console logging to view diskless client error messages. |
Choose Log Viewer from the console main window to view diskless client error messages. | |
2. Prepare for adding a diskless client. |
Verify supported releases and identify the platform, media path, and cluster (or software group) of each diskless client. |
x86: How to Prepare for Adding Diskless Clients in a GRUB Based Boot Environment How to Prepare for Adding Diskless Clients in Oracle Solaris 10 |
3. Add required OS services to an OS server. |
Add the OS services for the diskless clients you want to support by using the smosservice command. You must identify the platform, media path, and each diskless client platform that you want to support. | |
4. Locate and install any ARCH=all packages that were missed when you added OS services to the server. Note – To avoid having to add these packages to each diskless client individually, perform this task prior to adding diskless client support. |
The smosservice add command does not install any root (/) or /usr packages that are designated ARCH=all. These packages must be installed manually after adding the OS services to the OS server. | |
5. Add a diskless client. |
Add diskless client support by specifying all required information with the smdiskless command. |
x86: How to Add a Diskless Client in the GRUB Based Boot Environment |
6. Boot the diskless client. |
Verify that a diskless client was successfully added by booting the diskless client. | |
7. (Optional) Delete diskless client support. |
Delete support for a diskless client, if it is no longer required. | |
8. (Optional) Delete OS services for a diskless client. |
Delete OS services for a diskless client, if they are no longer needed. | |
9. (Optional) Patch OS services. |
Add, delete, list, or synchronize patches for diskless client OS services. |
