System Administration Guide: Basic Administration
When to Boot a System
The following table lists system administration tasks and the corresponding boot option that is used to complete the task.
Table 8–2 Booting a System
Reason for System Reboot
Appropriate Boot Option
Information for SPARC Based Systems
Information for x86 Based Systems
Turn off system power due to anticipated power outage.
Turn system power back on.
Chapter 10, Shutting Down a System (Tasks)
Change kernel parameters in the /etc/system file.
Reboot the system to run level 3 (multiuser level with NFS resources shared).
SPARC: How to Boot a System to Run Level 3 (Multiuser Level)
x86: How to Boot a System to Run Level 3 (Multiuser)
Perform file system maintenance, such as backing up or restoring system data.
Press Control-D from run level S to bring the system back to run level 3.
SPARC: How to Boot a System to Run Level S (Single-User Level)
x86: How to Boot a System to Run Level S (Single-User Level)
Repair a system configuration file such as /etc/system.
Interactive boot.
SPARC: How to Boot a System Interactively
x86: How to Boot a System Interactively
Add or remove hardware from the system.
Reconfiguration boot (also to turn on system power after adding or removing hardware).
Adding a System Disk or a Secondary Disk (Task Map) in System Administration Guide: Devices and File Systems
Boot the system by using the kernel debugger (kmdb) to track down a system problem.
Booting with the kmdb option.
SPARC: How to Boot the System With the Kernel Debugger (kmdb)
x86: How to Boot a System With the Kernel Debugger in the GRUB Boot Environment (kmdb)
Boot the system in failsafe mode to repair an important system file that is causing system boot failure.
Booting the failsafe archive.
How to Boot a SPARC Based System in Failsafe Mode
How to Boot an x86 Based System in Failsafe Mode
To recover from a hung system and force a crash dump.
Performing a recovery boot
SPARC: How to Force a Crash Dump and Reboot of the System
x86: How to Force a Crash Dump and Reboot of the System
