System Administration Guide: Basic Administration
Determining a System's Run Level
Display run level information by using the who -r command.
$ who -r
Use the who -r command to determine a system's current run level for any level.
Example 18–1 Determining a System's Run Level
This example displays information about a system's current run level and previous run levels.
$ who -r
 .    run-level 3  Dec 13 10:10  3  0 S
Output of who -r command
Description
run-level 3
Identifies the current run level
Dec 13 10:10
Identifies the date of last run level change
3
Also identifies the current run level
0
Identifies the number of times the system has been at this run level since the last reboot
S
Identifies the previous run level
