System Administration Guide: Basic Administration
SPARC: Forcing a Crash Dump and Reboot of the System
Forcing a crash dump and reboot of the system are sometimes necessary for troubleshooting purposes. The savecore feature is enabled by default.
For more information about system crash dumps, see Chapter 17, Managing System Crash Information (Tasks), in System Administration Guide: Advanced Administration.
ProcedureSPARC: How to Force a Crash Dump and Reboot of the System
Use this procedure to force a crash dump of the system. The example that follows this procedure shows how to use the halt -d command to force a crash dump of the system. You will need to manually reboot the system after running this command.
  1. Type the stop key sequence for your system.
    The specific stop key sequence depends on your keyboard type. For example, you can press Stop-A or L1-A. On terminals, press the Break key.
    The PROM displays the ok prompt.
  2. Synchronize the file systems and write the crash dump.
    > n
    ok sync
    After the crash dump is written to disk, the system will continue to reboot.
  3. Verify the system boots to run level 3.
    The login prompt is displayed when the boot process has finished successfully.
    hostname console login:
Example 14–2 SPARC: Forcing a Crash Dump and Reboot of the System by Using the halt -d Command
This example shows how to force a crash dump and reboot of the system jupiter by using the halt -d and boot command. Use this method to force a crash dump and reboot of the system.
# halt -d
Jul 21 14:13:37 jupiter halt: halted by root
panic[cpu0]/thread=30001193b20: forced crash dump initiated at user request
000002a1008f7860 genunix:kadmin+438 (b4, 0, 0, 0, 5, 0)
  %l0-3: 0000000000000000 0000000000000000 0000000000000004 0000000000000004
  %l4-7: 00000000000003cc 0000000000000010 0000000000000004 0000000000000004
000002a1008f7920 genunix:uadmin+110 (5, 0, 0, 6d7000, ff00, 4)
  %l0-3: 0000030002216938 0000000000000000 0000000000000001 0000004237922872
  %l4-7: 000000423791e770 0000000000004102 0000030000449308 0000000000000005
syncing file systems... 1 1 done
dumping to /dev/dsk/c0t0d0s1, offset 107413504, content: kernel
100% done: 5339 pages dumped, compression ratio 2.68, dump succeeded
Program terminated
ok boot
Resetting ...
Sun Ultra 5/10 UPA/PCI (UltraSPARC-IIi 333MHz), No Keyboard
OpenBoot 3.15, 128 MB memory installed, Serial #10933339.
Ethernet address 8:0:20:a6:d4:5b, Host ID: 80a6d45b.
Rebooting with command: boot
Boot device: /pci@1f,0/pci@1,1/ide@3/disk@0,0:a
File and args: kernel/sparcv9/unix
SunOS Release 5.10 Version s10_60 64-bit
Copyright 1983-2004 Sun Microsystems, Inc.  All rights reserved.
Use is subject to license terms.
configuring IPv4 interfaces: hme0.
add net default: gateway
Hostname: jupiter
The system is coming up.  Please wait.
NIS domain name is
System dump time: Wed Jul 21 14:13:41 2004
Jul 21 14:15:23 jupiter savecore: saving system crash dump
in /var/crash/jupiter/*.0
Constructing namelist /var/crash/jupiter/unix.0
Constructing corefile /var/crash/jupiter/vmcore.0
100% done: 5339 of 5339 pages saved
Starting Sun(TM) Web Console Version 2.1-dev...
