System Administration Guide: Basic Administration
ProcedureSPARC: How to Identify Devices on a System
You might need to identify the devices on the system to determine what are the appropriate devices to boot from.
Before You Begin
Before you can safely use the probe commands to determine what devices are attached to the system, you need to do the following:
You can view the probe commands that are available on your system by using the sifting probe command:
ok sifting probe
If you run the probe commands without clearing the system registers, the following message is displayed:
ok probe-scsi
This command may hang the system if a Stop-A or halt command
has been executed.  Please type reset-all to reset the system
before executing this command.
Do you wish to continue? (y/n) n
  1. Identify the devices on the system.
    ok probe-device
  2. (Optional) If you want the system to reboot after a power failure or after using the reset command, then reset the auto-boot? parameter to true.
    ok setenv auto-boot? true
    auto-boot? =          true
  3. Boot the system to multiuser mode.
    ok reset-all
Example 11–1 SPARC: Identifying the Devices on a System
The following example shows how to identify the devices connected to an Ultra 10 system.
ok setenv auto-boot? false
auto-boot? =          false
ok reset-all
Resetting ...
Sun Ultra 5/10 UPA/PCI (UltraSPARC-IIi 333MHz), No Keyboard
OpenBoot 3.15, 128 MB memory installed, Serial #10933339.
Ethernet address 8:0:20:a6:d4:5b, Host ID: 80a6d45b.
ok probe-ide
  Device 0  ( Primary Master )
          ATA Model: ST34321A
  Device 1  ( Primary Slave )
         Not Present
  Device 2  ( Secondary Master )
         Removable ATAPI Model: CRD-8322B
  Device 3  ( Secondary Slave )
         Not Present
auto-boot? =          true
Alternatively, you can use the devalias command to identify the device aliases and the associated paths of devices that might be connected to the system. For example:
ok devalias
screen                   /pci@1f,0/pci@1,1/SUNW,m64B@2
net                      /pci@1f,0/pci@1,1/network@1,1
cdrom                    /pci@1f,0/pci@1,1/ide@3/cdrom@2,0:f
disk                     /pci@1f,0/pci@1,1/ide@3/disk@0,0
disk3                    /pci@1f,0/pci@1,1/ide@3/disk@3,0
disk2                    /pci@1f,0/pci@1,1/ide@3/disk@2,0
disk1                    /pci@1f,0/pci@1,1/ide@3/disk@1,0
disk0                    /pci@1f,0/pci@1,1/ide@3/disk@0,0
ide                      /pci@1f,0/pci@1,1/ide@3
floppy                   /pci@1f,0/pci@1,1/ebus@1/fdthree
ttyb                     /pci@1f,0/pci@1,1/ebus@1/se:b
ttya                     /pci@1f,0/pci@1,1/ebus@1/se:a
keyboard!                /pci@1f,0/pci@1,1/ebus@1/su@14,3083f8:forcemode
keyboard                 /pci@1f,0/pci@1,1/ebus@1/su@14,3083f8
mouse                    /pci@1f,0/pci@1,1/ebus@1/su@14,3062f8
name                     aliases
