This chapter describes the procedures for booting the Oracle Solaris release on SPARC and x86 based systems.
The following is a list of the information that is in this chapter:
For overview information about the boot process, see Chapter 9, Shutting Down and Booting a System (Overview).
Starting with the Solaris 10 1/06 release, the open source GRand Unified Bootloader (GRUB) has been implemented on x86 based systems. GRUB is responsible for loading a boot archive, which contains the kernel modules and configuration files, into the system's memory.
For information about booting an x86 based system in a Solaris release that does not implement GRUB based booting, see Chapter 16, x86: Booting a System That Does Not Implement GRUB (Tasks).
Task |
Description |
For Instructions |
Boot a SPARC based system to run level 3. |
Use this boot method after shutting down the system or performing a system hardware maintenance task. |
SPARC: How to Boot a System to Run Level 3 (Multiuser Level) |
Boot a SPARC based system to run level S. |
Use this boot method to boot the system after performing a system maintenance task such as backing up a file system. At this level, only local file systems are mounted and users cannot log in to the system. |
SPARC: How to Boot a System to Run Level S (Single-User Level) |
Boot a SPARC based system interactively. |
Use this boot method after making temporary changes to a system file or the kernel for testing purposes. | |
Boot a Solaris kernel other than default. |
Use this procedure to boot a Solaris kernel other than the default kernel. Alternately, you can obtain a copy of an alternate boot file, change the default kernel to the new kernel, then set the boot-file parameter to boot the new default boot device. | |
Display a list of the available ZFS bootable datasets on a SPARC based system. |
Use the boot -L command to display a list of the available BEs within a ZFS pool on a system. Note – This option is only supported for boot devices that contain a ZFS pool. |
SPARC: How to List Available Bootable Datasets Within a ZFS Root Pool |
Boot a SPARC based system from a ZFS root file system. |
Use the boot -Z option to boot a specified ZFS dataset. Note – This option is only supported for boot devices that contain a ZFS pool. | |
Boot the failsafe archive on a SPARC based system. |
Use this procedure to boot a SPARC based system in failsafe mode. Then, run the bootadm command to update the boot archive. | |
Boot a SPARC based system from the network. |
Use this boot method to boot a system from the network. Note that this method is also used for booting a diskless client. |
If a system is turned off, turning it on starts the multiuser boot sequence. The following procedures show how to boot to different run levels from the ok PROM prompt. These procedures assume that the system has been cleanly shut down, unless stated otherwise.
Use the who -r command to verify that the system is brought to the specified run level. For a description of run levels, see Chapter 18, Managing Services (Overview).
Use this procedure to boot a system that is currently at run level 0 to run level 3.
Boot the system to run level 3.
ok boot |
The automatic boot procedure displays a series of startup messages, and brings the system to run level 3. For more information, see the boot(1M) man page.
Verify that the system has booted to run level 3.
The login prompt is displayed when the boot process has finished successfully.
hostname console login: |
The following example displays the messages from booting a system to run level 3.
ok boot Sun Ultra 5/10 UPA/PCI (UltraSPARC-IIi 333MHz) OpenBoot 3.15, 128 MB memory installed, Serial #number. Ethernet address number, Host ID: number. Rebooting with command: boot Boot device: /pci@1f,0/pci@1,1/ide@3/disk@0,0:a File and args: kernel/sparcv9/unix SunOS Release 5.10 Version s10_60 64-bit Copyright 1983-2004 Sun Microsystems, Inc. All rights reserved. Use is subject to license terms. configuring IPv4 interfaces: hme0. add net default: gateway 172.20.27.248 Hostname: starlite The system is coming up. Please wait. NIS domain name is example.com starting rpc services: rpcbind keyserv ypbind done. Setting netmask of hme0 to 255.255.255.0 Setting default IPv4 interface for multicast: add net 224.0/4: gateway starlite syslog service starting.The system is ready. Starting Sun(TM) Web Console Version 2.1-dev.. volume management starting. The system is ready. starlite console login: |
In the preceding example, sparcv9 was used as an example only. This string matches the output of the isainfo -k command.
Use this procedure to boot a system that is currently at run level 0 to run level S. This run level is used for system maintenance tasks, such as backing up a file system.
Boot the system to run level S.
ok boot -s |
Type the superuser password when the following message is displayed:
SINGLE USER MODE Root password for system maintenance (control-d to bypass): xxxxxx |
Verify that the system is at run level S.
# who -r |
Perform the maintenance task that required the run level change to S.
After you complete the system maintenance task, type Control-D to bring the system to the multiuser state.
The following example displays the messages from booting a system to run level S.
ok boot -s . . . Sun Microsystems Inc. SunOS 5.10 Version Generic_120012-14 32-bit Copyright 1983-2003 Sun Microsystems, Inc. All rights reserved. Use is subject to license terms. configuring IPv4 interfaces: hme0. Hostname: starlite SINGLE USER MODE Root password for system maintenance (control-d to bypass): xxxxxx single-user privilege assigned to /dev/console. Entering System Maintenance Mode Oct 14 15:01:28 su: 'su root' succeeded for root on /dev/console Sun Microsystems Inc. SunOS 5.10 # who -r . run-level S Sep 19 08:49 S 0 ? (Perform some maintenance task) # ^D |
Use this boot option when you need to specify an alternate kernel or /etc/system file.
To specify an alternate /etc/system file when booting a SPARC based system interactively by using the boot -a command, you must perform the following steps before the system is booted.
1. Make backup copies of the /etc/system and boot/solaris/filelist.ramdisk files.
# cp /etc/system /etc/system.bak # cp /boot/solaris/filelist.ramdisk /boot/solaris/filelist.ramdisk.orig |
2. Add the etc/system.bak file name to the /boot/solaris/filelist.ramdisk file.
# echo "etc/system.bak" >> /boot/solaris/filelist.ramdisk |
3. Update the boot archive.
# bootadm update-archive -v |
Boot the system interactively.
ok boot -a |
Answer the following system prompts:
When prompted, enter the name of the kernel to use for booting.
Press enter to use the default kernel file name. Otherwise, provide the name of an alternate kernel, press Enter.
When prompted, provide an alternate path for the modules directories.
Press enter to use the default module directories. Otherwise, provide the alternate paths to module directories, press Enter.
When prompted, provide the name of an alternate system file.
Type /dev/null if your /etc/system file has been damaged.
When prompted, enter the root filesystem type.
Press enter to select UFS for local disk booting, which is the default, or enter NFS for network booting.
When prompted, enter the physical name of root device.
Provide an alternate device name or press return to use the default.
If you are not prompted to answer these questions, verify that you typed the boot -a command correctly.
In this example, the default choices (shown in square brackets []) are accepted. For instructions and an example of booting an alternate file system by using the boot -a command, see SPARC: How to Boot a System Interactively.
ok boot -a . . . Rebooting with command: boot -a Boot device: /pci@1f,0/pci@1,1/ide@3/disk@0,0:a File and args: -a Enter filename [kernel/sparcv9/unix]: Press Return Enter default directory for modules [/platform/SUNW,Ultra-5_10/kernel /platform/sun4u/kernel /kernel /usr/kernel]: Press Return Name of system file [etc/system]: Press Return SunOS Release 5.10 Version S10_60 64-bit Copyright (c) 1983-2004 by Sun Microsystems, Inc. All rights reserved Use is subject to license terms. root filesystem type [ufs]: Press Return Enter physical name of root device [/pci@1f,0/pci@1,1/ide@3/disk@0,0:a]: Press Return configuring IPv4 interfaces: hme0. Hostname: starlite The system is coming up. Please wait. checking ufs filesystems . . . The system is ready. starlite console login: |
Become superuser or assume an equivalent role.
Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
Obtain a copy of an existing Oracle Solaris kernel and rename it.
Add the kernel that you copied and renamed in Step 2 to the /etc/boot/solaris/filelist.ramdisk file.
# echo "kernel.name" >> /boot/solaris/filelist.ramdisk |
Verify that the alternate kernel has been added to the /etc/boot/solaris/filelist.ramdisk file.
# cat > /etc/boot/solaris/filelist.ramdisk |
Update the boot archive by using the bootadm command.
# bootadm update-archive |
Change to run level 0.
# init 0 |
The ok PROM prompt is displayed.
Boot the alternate kernel.
ok boot alternate-kernel |
For example:
ok boot kernel.myname/sparcv9/unix |
After the system has booted, verify that the alternate kernel that was booted.
# prtconf -vp | grep whoami |
# cp -r /platform/sun4v/kernel /platform/sun4vu/kernel.caiobella # echo "kernel.caiobela" >> /boot/solaris/filelist.ramdisk # cat > /etc/boot/solaris/filelist.ramdisk /platform/sun4v/kernel.caiobella ^D (control D) ok setenv boot-file kernel.caiobells/sparcv9/unix ok printenv boot-file boot-file = kernel.caiobella/sparcv9/unix ok boot SC Alert: Host System has Reset SC Alert: Host system has shut down. Sun Fire T200, No KeyboardCopyright 2006 Sun Microsystems, Inc. All rights reserved. OpenBoot 4.25.0.build_01***PROTOTYPE BUILD***, 32760 MB memory available, Serial #69060038. Ethernet address 0:x:4f:x:c5:c6, Host ID: 8xxc5c6. Rebooting with command: boot Boot device: /pci@7c0/pci@0/pci@1/pci@0,2/LSILogic,sas@2/disk@0,0:a File and args: kernel.caiobella/sparcv9/unix SunOS Release 5.10 Copyright 1983-2007 Sun Microsystems, Inc. All rights reserved. Use is subject to license terms. DEBUG enabled misc/forthdebug (176650 bytes) loaded Hostname: seasonz NIS domain name is lab.domain.sun.com Reading ZFS config: done. seasonz console login: Password: Last login: Mon Nov 12 18:02:00 on console Sun Microsystems Inc. SunOS 5.10 . . . You have new mail. # # # prtconf -vp | grep whoami whoami: '/platform/sun4v/kernel.caiobella/sparcv9/unix' |
To support booting from an Oracle Solaris ZFS on the SPARC platform, two new boot options have been added:
Displays a list of available bootable datasets within a ZFS pool.
The boot -L command is executed from the OBP, not from the command line.
Boots the root file system for the specified ZFS bootable dataset.
If you are booting a system from a ZFS root file system, first use the boot command with the -L option from the OBP to print a list of the available BEs on the system. Then, use the -Z option to boot the specified BE.
On SPARC based systems, the menu.lst file contains the following two GRUB commands:
title – Provides a title for a boot environment (BE)
bootfs – Specifies the full name of the bootable dataset
To display a list of the bootable datasets within a ZFS pool, choose from the following methods:
Use the lustatus command. This command lists all of the BEs in a given ZFS pool.
Note that the lustatus command can also be used on x86 based systems.
Use the boot -L command. This command displays a list of the available BEs in a given ZFS pool and provides instructions for booting the system.
The following procedure describes how to use the boot -L command to list available BEs on a system. To boot a specified BE after running this command, follow the instructions that are printed on the screen.
Bring the system to the ok PROM prompt.
# init 0 |
List the available BEs in a ZFS pool:
ok boot device-specifier -L |
To boot one of the entries that is displayed, type the number that corresponds to the entry.
Boot the specified BE by following the directions that are printed on the screen.
For instructions, see SPARC: How to Boot From a Specified ZFS Root File System.
# init 0 # svc.startd: The system is coming down. Please wait. svc.startd: 94 system services are now being stopped. svc.startd: The system is down. syncing file systems... done Program terminated ok boot -L . . . Boot device: /pci@1f,0/pci@1/scsi@8/disk@0,0 File and args: -L zfs-file-system Loading: /platformsun4u/bootlst 1.s10s_nbu6wos 2 zfs2BE Select environment to boot: [ 1 - 2 ]: 2 to boot the selected entry, invoke: boot [<root-device] -Z rpool/ROOT/zfs2BE |
For more information, see Chapter 5, Installing and Booting an Oracle Solaris ZFS Root File System, in Oracle Solaris ZFS Administration Guide.
Booting from Oracle Solaris ZFS differs from booting from UFS. When booting from ZFS, a device specifier identifies a storage pool, not a single root file system. A storage pool can contain multiple bootable datasets, or root file systems. Therefore, when booting from ZFS, you must also identify a root file system within the pool that is identified by the boot device as the default. By default, the default boot device is identified by the pool's bootfs property. This procedure shows how to boot the system by specifying a ZFS bootable dataset. See the boot(1M) man page for a complete description of all the boot options that are available.
If the bootfs property was previously set up correctly, for example, if you used the luactivate command to activate a BE, the system boots a ZFS root automatically.
For more information, see zpool(1M) man page.
# init 0 |
(Optional) To display a list of available BEs, use the boot command with the -L option.
For instructions, see SPARC: How to List Available Bootable Datasets Within a ZFS Root Pool.
To boot a specified entry, type the number of the entry and press Return:
Select environment to boot: [1 - 2]: |
To boot the system, follow the instructions that are printed to the screen:
To boot the selected entry, invoke: boot [<root-device>] -Z rpool/ROOT/dataset
ok boot -Z rpool/ROOT/dataset |
For example:
# boot -Z rpool/ROOT/zfs2BE |
After the system has booted, type the following command to verify the active BE:
This example shows how to use the boot -Z command to boot a ZFS dataset on a SPARC based system.
# init 0 # svc.startd: The system is coming down. Please wait. svc.startd: 79 system services are now being stopped. svc.startd: The system is down. syncing file systems... done Program terminated ok boot -Z rpool/ROOT/zfs2BEe Resetting LOM event: =44d+21h38m12s host reset g ... rProcessor Speed = 648 MHz Baud rate is 9600 8 Data bits, 1 stop bits, no parity (configured from lom) Firmware CORE Sun Microsystems, Inc. @(#) core 1.0.12 2002/01/08 13:00 software Power ON Verifying nVRAM...Done Bootmode is 0 [New I2C DIMM address] . . . Environment monitoring: disabled Executng last command: boot -Z rpool/ROOT/zfs2BE Boot device: /pci@1f,0/pci@1/scsi@8/disk@0,0 File and args: -Z rpool/ROOT/zfs2Be zfs-file-system Loading: /platform/SUNW,UltraAX-i2/boot_archive Loading: /platform/sun4u/boot_archive ramdisk-root hsfs-file-system Loading: /platform/SUNW,UltraAX-i2/kernel/sparcv9/unix Loading: /platform/sun4u/kernel/sparcv9/unix . . . Hostname: mallory NIS domainname is boulder.Central.Sun.COM Reading ZFS config: done. Mounting ZFS filesytems: (6/6) mallory console login: |
For information about booting the failsafe archive for a specified ZFS bootable dataset, see How to Boot a SPARC Based System in Failsafe Mode.
Booting a system from a root file system image that is a boot archive, and then remounting this file system on the actual root device can sometimes result in a boot archive and root file system that do not match, or are inconsistent. Under these conditions, the proper operation and integrity of the system is compromised. After the root (/) file system is mounted, and before relinquishing the in-memory file system, the system performs a consistency verification against the two files systems. If an inconsistency is detected, the normal boot sequence is suspended and the system reverts to failsafe mode.
Also, if a system failure, a power failure, or a kernel panic occurs immediately following a kernel file update, the boot archives and the root (file system might not be synchronized. Although the system might still boot with the inconsistent boot archives, it is recommended that you boot the failsafe archive to update the boot archives. You can also use the bootadm command to manually update the boot archives. For more information, see Using the bootadm Command to Manage the Boot Archives.
The failsafe archive can be booted for recovery purposes, or to update the boot archive.
On the SPARC platform the failsafe archive is:
/platform/`uname -m`/failsafe
You would boot the failsafe archive by using the following syntax:
ok boot -F failsafe |
Failsafe booting is also supported on systems that are booted from Oracle Solaris ZFS. When booting from a ZFS-rooted BE, each BE has its own failsafe archive. The failsafe archive is located where the root file system is located, as is the case with a UFS-rooted BE. The default failsafe archive is the archive that is in the default bootable file system. The default bootable file system (dataset) is indicated by the value of the pool's bootfs property.
For information about booting an x86 based failsafe archive, see Booting an x86 Based System in Failsafe Mode.
For information about clearing automatic boot archive failures, see x86: How to Clear Automatic Boot Archive Update Failures by Using the auto-reboot-safe Property.
Use this procedure to boot a SPARC based system in failsafe mode for the purpose of updating the boot archive. If the system does not boot after the boot archive is updated, you might need to boot the system in single-user mode. For more information, see SPARC: How to Boot a System to Run Level S (Single-User Level).
This procedures also provides instructions for booting a specific ZFS dataset in failsafe mode.
Bring the system to the ok prompt:
# init 0 |
Boot the failsafe archive.
To boot the default failsafe archive, type:
To boot the failsafe archive of a specific ZFS dataset:
ok boot -F failsafe -Z dataset |
For example:
ok boot -F failsafe -Z rpool/ROOT/zfsBE2 |
To determine the name of the dataset to boot, first use the boot -L command to display a list of the available BEs on the system. For more information, see SPARC: How to List Available Bootable Datasets Within a ZFS Root Pool.
If an inconsistent boot archive is detected a message is displayed.
To update the boot archive, type y, then press Return.
An out of sync boot archive was detected on rpool. The boot archive is a cache of files used during boot and should be kept in sync to ensure proper system operation. Do you wish to automatically update this boot archive? [y,n,?] y |
If the archive was updated successfully, a message is displayed:
The boot archive on rpool was updated successfully. |
This example shows how to boot a SPARC based system in failsafe mode. If no device is specified, the failsafe archive for the default boot device is booted.
ok boot -F failsafe Resetting ... screen not found. Can't open input device. Keyboard not present. Using ttya for input and output. Sun Enterprise 220R (2 X UltraSPARC-II 450MHz), No Keyboard OpenBoot 3.23, 1024 MB memory installed, Serial #13116682. Ethernet address 8:0:20:c8:25:a, Host ID: 80c8250a. Rebooting with command: boot -F failsafe Boot device: /pci@1f,4000/scsi@3/disk@1,0:a File and args: -F failsafe SunOS Release 5.10t Copyright 1983-2007 Sun Microsystems, Inc. All rights reserved. Use is subject to license terms. Configuring /dev Searching for installed OS instances... An out of sync boot archive was detected on /dev/dsk/c0t1d0s0. The boot archive is a cache of files used during boot and should be kept in syncto ensure proper system operation. Do you wish to automatically update this boot archive? [y,n,?] y Updating boot archive on /dev/dsk/c0t1d0s0. The boot archive on /dev/dsk/c0t1d0s0 was updated successfully. Solaris 5.10 was found on /dev/dsk/c0t1d0s0. Do you wish to have it mounted read-write on /a? [y,n,?] n Starting shell. # |
This example shows how to boot the a ZFS dataset in failsafe mode. Note that the boot -L command is first used to display a list of available boot environments. This command must be run at the ok prompt.
ok boot -L Rebooting with command: boot -L Boot device: /pci@1f,4000/scsi@3/disk@1,0 File and args: -L 1 zfsBE2 Select environment to boot: [ 1 - 1 ]: 1 To boot the selected entry, invoke: boot [<root-device>] -Z rpool/ROOT/zfsBE2 Program terminated {0} ok Resetting ... screen not found. Can't open input device. Keyboard not present. Using ttya for input and output. Sun Enterprise 220R (2 X UltraSPARC-II 450MHz), No Keyboard OpenBoot 3.23, 1024 MB memory installed, Serial #13116682. Ethernet address 8:0:20:c8:25:a, Host ID: 80c8250a. {0} ok boot -F failsafe -Z rpool/ROOT/zfsBE2 Boot device: /pci@1f,4000/scsi@3/disk@1,0 File and args: -F failsafe -Z rpool/ROOT/zfsBE2 SunOS Release 5.10 Copyright 1983-2008 Sun Microsystems, Inc. All rights reserved. Use is subject to license terms. Configuring /dev Searching for installed OS instances... ROOT/zfsBE2 was found on rpool. Do you wish to have it mounted read-write on /a? [y,n,?] y mounting rpool on /a Starting shell. # # # # zpool list NAME SIZE USED AVAIL CAP HEALTH ALTROOT rpool 16.8G 6.26G 10.5G 37% ONLINE /a # # zpool status pool: rpool state: ONLINE scrub: none requested config: NAME STATE READ WRITE CKSUM rpool ONLINE 0 0 0 c0t1d0s0 ONLINE 0 0 0 errors: No known data errors # # df -h Filesystem size used avail capacity Mounted on /ramdisk-root:a 163M 153M 0K 100% / /devices 0K 0K 0K 0% /devices /dev 0K 0K 0K 0% /dev ctfs 0K 0K 0K 0% /system/contract proc 0K 0K 0K 0% /proc mnttab 0K 0K 0K 0% /etc/mnttab swap 601M 344K 601M 1% /etc/svc/volatile objfs 0K 0K 0K 0% /system/object sharefs 0K 0K 0K 0% /etc/dfs/sharetab swap 602M 1.4M 601M 1% /tmp /tmp/root/etc 602M 1.4M 601M 1% /.tmp_proto/root/etc fd 0K 0K 0K 0% /dev/fd rpool/ROOT/zfsBE2 16G 5.7G 9.8G 37% /a rpool/export 16G 20K 9.8G 1% /a/export rpool/export/home 16G 18K 9.8G 1% /a/export/home rpool 16G 63K 9.8G 1% /a/rpool |
You might need to boot a system from the network under the following conditions:
When the system is first installed
If the system won't boot from the local disk
If the system is a diskless client
Two network configuration boot strategies are available:
Reverse Address Resolution Protocol (RARP) and ONC+ RPC Bootparams Protocol
Dynamic Host Configuration Protocol (DHCP)
For network devices, the process for booting over a local area network (LAN) and booting over a wide area network (WAN) is slightly different. In both network boot scenarios, the PROM downloads the booter from a boot server or an installation server, which is inetboot in this case.
When booting over a (LAN), the firmware uses RARP and BOOTP or DHCP to discover the boot or installation server. TFTP is then used to download the booter, which is inetboot in this case.
When booting over a WAN, the firmware uses either DHCP or NVRAM properties to discover the installation server, the router, and the proxies that are required for the system to boot from the network. The protocol that is used to download the booter is HTTP. In addition, the booter's signature might be checked with a predefined private key.
Any system can boot from the network, if a boot server is available. You might want to boot a stand-alone system from the network if the system cannot boot from the local disk. For information on changing or resetting the default boot device, see SPARC: How to Change the Default Boot Device by Using the Boot PROM.
Two network configuration boot strategies are available on sun–4u systems:
RARP – Reverse Address Resolution Protocol and ONC+ RPC Bootparams Protocol
DHCP – Dynamic Host Configuration Protocol
The default network boot strategy is set to RARP. You can use either protocol, depending on whether a RARP boot server or a DHCP boot server is available on your network.
Sun Ultra systems must have at least PROM version 3.25.nn to use the DHCP network boot strategy. For information on determining your PROM version, see SPARC: How to Find the PROM Revision Number for a System.
If both protocols are available, you can temporarily specify which protocol to use in the boot command. Or, you can save the network boot strategy across system reboots at the PROM level by setting up an NVRAM alias. The following example uses the nvalias command to set up a network device alias for booting with DHCP by default on a Sun Ultra 10 system.
ok nvalias net /pci@1f,4000/network@1,1:dhcp |
As a result, when you type boot net, the system boots by using DHCP.
Do not use the nvalias command to modify the NVRAMRC file, unless you are very familiar with the syntax of this command and the nvunalias command. For information about using these commands, see the OpenBoot 3.x Command Reference Manual.
To boot with either protocol successfully, you must have already set up a RARP or DHCP boot server on your network.
If necessary, shut down the system.
Determine the method for booting from the network, then select one of the following:
Boot the system from the network by using the DHCP strategy.
ok boot net[:dhcp] |
If you have changed the PROM setting to boot with DHCP by default, as in the preceding nvalias example, you only have to specify boot net.
Boot the system from the network by using the RARP strategy.
ok boot net[:rarp] |
Because RARP is the default network boot strategy, you only have to specify boot net:rarp if you have changed the PROM value to boot DHCP.
Task |
Description |
For Instructions |
Boot an x86 based system to run level 3, multiuser level. |
Use this boot method to bring the system back to multiuser level after shutting down the system or performing a system hardware maintenance task. | |
Boot an x86 based system in single-user mode. |
Use this boot method to perform a system maintenance task, such as backing up a file system. |
x86: How to Boot a System to Run Level S (Single-User Level) |
Boot an x86 based system interactively. |
Display a list of bootable ZFS datasets on an x86 based system. |
Use one of the following methods to display the available BEs on an x86 based system that has a ZFS root file system:
x86: How to Display a List of the Available ZFS Boot Environments |
Boot an x86 based system from a ZFS root file system. |
If you install or upgrade your system to an Oracle Solaris release that supports a ZFS boot loader, the GRUB menu entry for the default ZFS BE contains the -B $ZFS-BOOTFS boot argument by default. The system boots automatically from ZFS. Note – This option is supported only for boot devices that contain a ZFS pool. | |
Boot an x86 based system in failsafe mode. |
Use this procedure to boot the failsafe archive on an x86 based system. Then, run the bootadm command to update the boot archive. | |
Boot an x86 based system in failsafe mode to forcibly update a corrupt boot archive. |
Use this procedure in cases where the boot archive is corrupt, and the system refuses to boot normally, or you are not prompted to update an inconsistent boot archive. |
x86: How to Boot in Failsafe Mode to Forcibly Update a Corrupt Boot Archive |
Boot an x86 based system from the network by using GRUB. |
Use this method to boot a PXE or non-PXE device from the network with the default network configuration strategy. This method is also used for booting a diskless client. |
Reboot the system.
# reboot |
If the system displays the Press any key to reboot prompt, press any key to reboot the system.
You can also use the Reset button at this prompt. If the system is shut down, turn the system on with the power switch.
When the boot sequence begins, the GRUB menu is displayed.
When the GRUB menu is displayed, press Enter to boot the default OS instance.
If you do not choose an entry within 10 seconds, the system automatically boots to run level 3.
Log in to the system.
Verify that the system booted to run level 3.
# who -r system% who -r . run-level 3 Mar 2 09:44 3 0 S |
# reboot Jul 24 11:29:52 bearskin reboot: rebooted by root syncing file systems... done rebooting... Adaptec AIC-7899 SCSI BIOS v2.57S4 (c) 2000 Adaptec, Inc. All Rights Reserved. Press <Ctrl><A> for SCSISelect(TM) Utility! Ch B, SCSI ID: 0 SEAGATE ST336607LSUN36G 160 GNU GRUB version 0.95 (637K lower / 2096064K upper memory) ============================================================== Solaris 10 10/08 s10x_u6wos_03 X86 Solaris failsafe ============================================================== Use the and keys to select which entry is highlighted. Press enter to boot the selected OS, 'e' to edit the commands before booting, or 'c' for a command-line. SunOS Release 5.10 Version Generic_137138-04 32-bit Copyright 1983-2008 Sun Microsystems, Inc. All rights reserved. Use is subject to license terms. Hostname: pups NIS domain name is ....sfbay.sun.com Reading ZFS config: done. Mounting ZFS filesystems: (5/5) pups console login: # who -r . run-level 3 Jul 24 11:31 3 0 S |
Use this procedure to boot a system that is at run level 0 to run level S. The single-user level is used for performing system maintenance.
This procedure can be used for all GRUB implementations. However, the boot entries in the GRUB main menu vary, depending on which Oracle Solaris release you are running.
For a description of all of the kernel options that you can specify at boot time, see x86: Modifying Boot Behavior by Editing the GRUB Menu at Boot Time.
Reboot the system.
# reboot |
When the GRUB main menu is displayed, type e to edit the GRUB menu.
Depending on the release you are running, use the arrow keys to choose the kernel or kernel$ line.
If you cannot use the arrow keys, use the caret key (^) key to scroll up and the letter v key to scroll down.
Type e again to edit the boot entry.
From here, you can add options and arguments to the kernel or kernel$ line.
To boot the system in single-user mode, type -s at the end of the boot entry line, then press Return to go back to the previous screen.
To specify other boot behaviors, replace the -s option with the appropriate boot option.
The following alternate boot behaviors can be specified in this manner:
Perform a reconfiguration boot
Boot a 64-bit capable system in 32-bit mode
Boot the system with the kernel debugger
Redirect the console
To boot the system in single-user mode, type b.
When prompted, type the root password.
# who -r . run-level S Jun 13 11:07 S 0 0 |
Perform the system maintenance task that required the run level change to S.
After you complete the system maintenance task, reboot the system.
# reboot Jul 2 14:30:01 pups reboot: initiated by root on /dev/console syncing files... Press <Ctrl><A> forPSCSISelect(TM) Utility! GNU GRUB version 0.95 (637K lower / 2096064K upper memory) =================================================== Solaris 10 10/08 s10x_u6wos_03 X86 Solaris failsafe ===================================================== Use the and keys to select which entry is highlighted. Press enter to boot the selected OS, 'e' to edit the commands before booting, or 'c' for a command-line. ===================================================== GNU GRUB version 0.95 (637K lower / 2096064K upper memory) ===================================================== findroot (pool_rpool,0,a) kernel$ /platform/i86pc/multiboot -B $ZFS-BOOTFS module /platform/i86pc/boot_archive ================================================ Use the and keys to select which entry is highlighted. Press 'b' to boot, 'e' to edit the selected command in the boot sequence, 'c' for a command-line, 'o' to open a new line after ('O' for before) the selected line, 'd' to remove the selected line, or escape to go back to the main menu. [ Minimal BASH-like line editing is supported. For the first word, TAB lists possible command completions. Anywhere else TAB lists the possible completions of a device/filename. ESC at any time exits. ] grub edit> kernel$ /platform/i86pc/multiboot -B $ZFS-BOOTFS -s GNU GRUB version 0.95 (637K lower / 2096064K upper memory) ======================================================= findroot (pool_rpool,0,a) kernel$ /platform/i86pc/multiboot -B $ZFS-BOOTFS -s module /platform/i86pc/boot_archive ====================================== Use the and keys to select which entry is highlighted. Press 'b' to boot, 'e' to edit the selected command in the boot sequence, 'c' for a command-line, 'o' to open a new line after ('O' for before) the selected line, 'd' to remove the selected line, or escape to go back to the main menu. . . . SunOS Release 5.10 Copyright 1983-2008 Sun Microsystems, Inc. All rights reserved. Use is subject to license terms. Booting to milestone "milestone/single-user:default". Hostname: pups Requesting System Maintenance Mode SINGLE USER MODE Root password for system maintenance (control-d to bypass): single-user privilege assigned to /dev/console. Entering System Maintenance Mode Jul 2 14:41:48 su: 'su root' succeeded for root on /dev/console Sun Microsystems Inc. # who -r who -r . run-level S Jul 2 14:39 S 0 0 # |
Use this procedure to boot a system, if you need to specify an alternate kernel or an alternate /etc/system file.
To specify an alternate /etc/system file when booting an x86 based system interactively by using the boot -a command, follow these steps:
1. Make backup copies of the /etc/system and the boot/solaris/filelist.ramdisk files.
2. Add the /etc/system.bak file name to the /boot/solaris/filelist.ramdisk file.
Reboot the system.
# reboot |
When the boot sequence begins, the GRUB main menu is displayed.
To access the GRUB edit menu, type e.
Use the arrow keys to select the kernel or kernel$ line.
Type e to edit the boot entry line.
Type -a to boot the system interactively, then, press Enter to return to the previous menu.
To boot the system interactively, type b.
Type a default directory for modules, or press Enter to accept the default.
Enter default directory for modules [/platform/i86pc/kernel /kernel /usr/kernel]: |
Type an alternate system file name, alternate-file.
Name of system file [etc/system]: /etc/system.bak |
Pressing Enter without providing an alternate file accepts the default.
Repair the damaged /etc/system file.
Reboot the system to run level 3.
# reboot syncing file systems... done rebooting... GNU GRUB version 0.95 (637K lower / 2096064K upper memory) =================================================== Solaris 10 10/08 s10x_u6wos_03 X86 Solaris failsafe ===================================================== Use the and keys to select which entry is highlighted. Press enter to boot the selected OS, 'e' to edit the commands before booting, or 'c' for a command-line. ===================================================== GNU GRUB version 0.95 (637K lower / 2096064K upper memory) ===================================================== findroot (pool_rpool,0,a) kernel$ /platform/i86pc/multiboot -B $ZFS-BOOTFS module /platform/i86pc/boot_archive ====================================================== Use the and keys to select which entry is highlighted. Press 'b' to boot, 'e' to edit the selected command in the boot sequence, 'c' for a command-line, 'o' to open a new line after ('O' for before) the selected line, 'd' to remove the selected line, or escape to go back to the main menu. [ Minimal BASH-like line editing is supported. For the first word, TAB lists possible command completions. Anywhere else TAB lists the possible completions of a device/filename. ESC at any time exits. ] grub edit> kernel$ /platform/i86pc/multiboot -B $ZFS-BOOTFS -a GNU GRUB version 0.95 (637K lower / 2096064K upper memory) =================================================== findroot (pool_rpool,0,a) kernel$ /platform/i86pc/multiboot -B $ZFS-BOOTFS -a module /platform/i86pc/boot_archive ==================================================== . . . Enter default directory for modules [/platform/i86pc/kernel /kernel /usr/kernel]: Name of system file [/etc/system]: /etc/system.bak SunOS Release 5.10 Version Generic_137138-04 32-bit Copyright 1983-2008 Sun Microsystems, Inc. All rights reserved. Use is subject to license terms. Hostname: pups NIS domain name is ....sfbay.sun.com Reading ZFS config: done. Mounting ZFS filesystems: (5/5) pups console login: |
To support booting an Oracle Solaris ZFS root file system on the x86 platform, a new GRUB keyword, $ZFS-BOOTFS, has been introduced. If a root device contains a ZFS pool, this keyword is assigned a value, which is then passed to the kernel with the -B option. This option identifies which dataset to boot. If you install or upgrade your system with an Oracle Solaris release that supports a ZFS boot loader, the GRUB menu.lst file, as well as the GRUB boot menu, contains this information by default.
To display a list of available BEs on the system, type the following command:
~# bootadm list-menu |
# lustatus |
Note that the lustatus command can also be used on SPARC based systems.
If the following error is displayed when you run the lustatus command, it is an indication that a new installation was performed and that Solaris Live Upgrade was not used. Before any BEs can be acknowledged in the lustatus output, a new BE must be first created on the system.
# lustatus ERROR: No boot environments are configured on this system ERROR: cannot determine list of all boot environment names |
For more information about using Solaris Live Upgrade to migrate a UFS root file system to a ZFS root file system, see Migrating a UFS Root File System to a ZFS Root File System (Oracle Solaris Live Upgrade) in Oracle Solaris ZFS Administration Guide.
In this example, the output of the lustatus command shows the status of three ZFS bootable datasets. The default boot environment is be1 and therefore cannot be deleted.
# lustatus Boot Environment Is Active Active Can Copy Name Complete Now On Reboot Delete Status -------------------------- -------- ------ --------- ------ ---------- s10s_nbu6wos yes no no yes - zfs2BE yes yes yes no - zfsbe3 no no no yes - # |
If the BE has been created and is bootable, a “yes” appears in the Is Complete column. If a BE has been created, but is not yet activated, a 'no” appears in this column. To activate a BE, use the luactivate command. Run the lustatus command afterwards to verify that the BE was successfully activated.
For more information see the lustatus(1M) and the luactivate(1M)man pages.
This procedure describes how to boot from a ZFS root file system on an x86 system that supports a ZFS boot loader.
Note that if you install or upgrade your system to an Oracle Solaris release that supports a ZFS boot loader, the GRUB menu entry contains the -B $ZFS-BOOTFS boot argument by default, so the system boots from ZFS without requiring any additional boot arguments.
Reboot the system.
# reboot |
When the boot sequence begins, the GRUB main menu is displayed. If the default boot entry is a ZFS file system menu is similar to the following:
GNU GRUB version 0.95 (637K lower / 3144640K upper memory) +----------------------------------------------------------------+ | be1 | be1 failsafe | be3 | be3 failsafe | be2 | be2 failfafe +---------------------------------------------------------------+ Use the ^ and v keys to select which entry is highlighted. Press enter to boot the selected OS, 'e' to edit the commands before booting, or 'c' for a command-line. |
To boot another BE, use the arrow keys to highlight the specified boot entry.
Type b to boot this entry or e to edit the entry.
For more information about GRUB menu entries at boot time, seex86: How to Modify Boot Behavior by Editing the GRUB Menu at Boot Time.
This example shows the steps that are followed to activate a boot environment, be10, on a system. Note that the lustatus command is run first, to determine which BEs on the system are active and which BEs require activation.
# lustatus Boot Environment Is Active Active Can Copy Name Complete Now On Reboot Delete Status ----------------------------------------------------------------- be1 yes yes yes no be10 yes no no yes # luactivate be10 System has findroot enabled GRUB Generating boot-sign, partition and slice information for PBE <be1> WARNING: The following file s have change on both the current boot environment <be1> zone <global> and the boot environment to be activitate <be10> /etc/zfs/zpool.cache INFORMATION: The files listed above are in conflict between the current boot environment <be1> zone <global> and the boot environment to be activated <be10>. These files will not be automatically synchronized from the current boot environment <be1> when boot environment <be10> is activated. Setting failsafe console to <ttyb> Generating boot-sign for ABE <be10> Generating partition and slice information for ABE <be10> Copied boot menu from top level dataset. Generating direct boot menu entries for PBE. Generating direct boot menu entries for ABE. Disabling splashimage Current GRUB menu default setting is not valid title Solaris bootenv rc No more bootadm entries. Deletion of bootadm entries is complete. GRUB menu default setting is unchanged Done eliding bootadm entries. ************************************************************** The target boot environment has been activated. It will be used when you reboot. NOTE: You MUST NOT USE the reboot, halt, or uadmin commands. You MUST USE either the init or the shutdown command when you reboot. If you do not use either init or shutdown, the system will not boot using the target BE. *************************************************************** ,,, # reboot May 30 09:52:32 pups reboot: initiated by root on /dev/console syncing file systems... done rebooting... CE SDRAM BIOS P/N GR-xlint.007-4.330 * BIOS Lan-Console 2.0 Copyright (C) 1999-2001 Intel Corporation . . . GNU GRUB version 0.95 (637K lower / 3144640K upper memory) +-------------------------------------------------------------------+ | be1 | be1 failsafe | be10 | be10 failsafe +------------------------------------------------------------------+ Use the ^ and v keys to select which entry is highlighted. Press enter to boot the selected OS, 'e' to edit the commands before booting, or 'c' for a command-line. SunOS Release 5.10 32-bit Copyright 1983-2008 Sun Microsystems, Inc. All rights reserved. Use is subject to license terms. Hostname: pups NIS domain name is sunsoft.eng.sun.com Reading ZFS config: done. Mounting ZFS filesystems: (8/8) pups console login: # lustatus Boot Environment Is Active Active Can Copy Name Complete Now On Reboot Delete Status ----------------------------------------------------------------- be1 yes yes yes no be10 yes yes yes no # |
To boot an x86 based system in failsafe mode, select the failsafe boot entry when the GRUB menu is displayed during a system boot. During the failsafe boot procedure, when prompted by the system, type y to update the primary boot archive.
Failsafe booting is also supported on systems that are booted from ZFS. When booting from a UFS-rooted BE, each BE has its own failsafe archive. The failsafe archive is located where the root file system is located, as is the case with a ZFS-rooted BE. On x86 based systems, each failsafe archive has an entry in the pool-wide GRUB menu. The default failsafe archive is the archive that is in the default bootable file system. The default bootable file system (dataset) is indicated by the value of the pool's bootfs property.
For more information about boot archive recovery, see the Chapter 13, Managing the Oracle Solaris Boot Archives (Tasks).
The GRUB failsafe interaction in some Oracle Solaris releases prompts you to update the boot archive, regardless of whether any inconsistent boot archive are detected. In this release, the system only prompts you to update the boot archive if an inconsistent boot archive is detected.
Stop the system by using one of the methods described in the procedure, x86: How to Stop a System for Recovery Purposes.
You can also use the Reset button at this prompt. Or, you can use the power switch to reboot the system.
GNU GRUB version 0.95 (637K lower / 3144640K upper memory) +-------------------------------------------------------------------+ | be1 | be1 failsafe | be3 | be3 failsafe | be2 | be2 failfafe +------------------------------------------------------------------+ Use the ^ and v keys to select which entry is highlighted. Press enter to boot the selected OS, 'e' to edit the commands before booting, or 'c' for a command-line. |
The GRUB menu that is displayed varies, depending on which Oracle Solaris release you are running.
Use the arrow keys to navigate the GRUB menu to select a failsafe entry.
Press Return to boot the failsafe archive.
The system searches for installed OS instances. If an inconsistent boot archive is detected, a message similar to the following is displayed:
Searching for installed OS instances... An out of sync boot archive was detected on /dev/dsk/c0t0d0s0. The boot archive is a cache of files used during boot and should be kept in sync to ensure proper system operation. Do you wish to automatically update this boot archive? [y,n,?] |
Type y to update the boot archive.
If multiple inconsistent boot archives are detected, the system will prompt you to type y to update each inconsistent boot archive.
For each archive that is updated successfully, the following message is displayed:
Updating boot archive on /dev/dsk/c0t0d0s0. The boot archive on /dev/dsk/c0t0d0s0 was updated successfully. |
After the boot archive is updated, the system searches again for all installed OS instances, then prompts you to select a device to mount on /a. Note that this same message is displayed when the system first boots if no inconsistent boot archives are detected.
Searching for installed OS instances... Multiple OS instances were found. To check and mount one of them read-write under /a, select it from the following list. To not mount any, select 'q'. 1 pool10:13292304648356142148 ROOT/be10 2 rpool:14465159259155950256 ROOT/be01 Please select a device to be mounted (q for none) [?,??,q]: |
This procedure shows how to rebuild an inconsistent or corrupt boot archive in the event you are not prompted by the system to update the boot archive the system, or in the event of a system hang or looping sequence occurs.
Stop the system by using one of the methods that are described in the procedure, x86: How to Stop a System for Recovery Purposes.
Reboot the system.
# reboot |
+---------------------------------------------------------------------+ | Solaris 10.1... X86 | | Solaris failsafe | | | | | +-------------------------------------------------------------------------+ Use the and keys to select which entry is highlighted. Press enter to boot the selected OS, 'e' to edit the commands before booting, or 'c' for a command-line. |
The contents of the GRUB menus vary, depending on the Solaris release you are running.
Use the arrow keys to navigate the GRUB menu to select the failsafe entry.
If any boot archives are out of date, a message t similar to the following is displayed:
Type y, then press Enter to update the inconsistent boot archive.
The system displays the following message:
If no inconsistent boot archives are found, a message similar to the following is displayed:
Searching for installed OS instances... Solaris 10.1... X86 was found on /dev/dsk/c0t0d0s0. Do you wish to have it mounted read-write on /a? [y,n,?] |
This message is also displayed after any inconsistent boot archives are updated successfully.
Mount the device that contains the corrupt boot archive on /a by typing the corresponding number of the device, then pressing Enter..
If any inconsistent boot archives were updated in the previous step, the device is already mounted on /a.
To forcibly update the corrupt boot archive, type:
# bootadm update-archive -f -R /a |
Unmount the device.
# umount /a |
Reboot the system.
# reboot |
This example shows how to boot the failsafe archive to forcibly update a corrupt boot archive.
GNU GRUB version 0.95 (635K lower / 523200K upper memory) +-------------------------------------------------------------------------+ | Solaris 10 1/06 s10x_u1wos_19a X86 | | >Solaris failsafe< | | | | | +-------------------------------------------------------------------------+ Use the and keys to select which entry is highlighted. Press enter to boot the selected OS, 'e' to edit the commands before booting, or 'c' for a command-line. SunOS Release 5.10 Copyright 1983-2006 Sun Microsystems, Inc. All rights reserved. Use is subject to license terms. Booting to milestone "milestone/single-user:default". Configuring devices. Searching for installed OS instances... Multiple OS instances were found. To check and mount one of them read-write under /a, select it from the following list. To not mount any, select 'q'. 1 /dev/dsk/c0t0d0s0 Solaris 10 1/06 s10x_u1wos_19a X86 2 /dev/dsk/c0t1d0s0 Solaris 10 5/08 X86 Please select a device to be mounted (q for none) [?,??,q]: 1 mounting /dev/dsk/c0t0d0s0 on /a Starting shell. # rm /a/platform/i86pc/boot_archive # bootadm update-archive -f -R /a Creating boot_archive for /a updating /a/platform/i86pc/amd64/boot_archive updating /a/platform/i86pc/boot_archive # umount /a # reboot syncing file systems... done rebooting... . . . |
This section describes the requirements and warnings for performing a GRUB based boot from the network.
Any system can boot from the network, if a boot server is available. You might need to boot a stand-alone system from the network for recovery purposes if the system cannot boot from the local disk. You can boot an x86 based system directly from a network that supports the PXE network boot protocol.
The PXE network boot is available only for devices that implement the Intel Preboot Execution Environment specification.
The default network boot strategy that is used for a GRUB based PXE network boot is DHCP. For non-PXE devices, you can use either the DHCP or the RARP boot strategy. The strategy that you use depends on which type of boot server is available on your network. If no PXE or DHCP server is available, you can load GRUB from a diskette, a CD-ROM, or a local disk.
To perform a GRUB based network boot, a DHCP server that is configured for PXE clients is required. A boot server that provides tftp service is also required. The DHCP server supplies the information that the client needs to configure its network interface.
The DHCP server must be able to respond to the DHCP classes, PXEClient and GRUBClient with the following information:
IP address of the file server
Name of the boot file (pxegrub)
The sequence for performing a PXE network boot of the Oracle Solaris OS is as follows:
The BIOS is configured to boot from a network interface.
The BIOS sends a DHCP request.
The DHCP server replies with the server address and the name of the boot file.
The BIOS downloads pxegrub by using tftp and executes pxegrub.
The system downloads a GRUB menu file by using tftp.
This file displays the boot menu entries that are available.
After you select a menu entry, the system begins to load the Oracle Solaris OS.
See How to Set Up a Network Configuration Server in System Administration Guide: IP Services for more information.
Running the add_install_client command creates the /tftpboot_01ethernet-address file. This file is linked to pxegrub and the/tftpboot/menu.lst.01ethernet-address file. The /tftpboot/menu.lst.01ethernet-address file is the GRUB menu file. If this file does not exist, then pxegrub reverts to using DHCP Option 150, if this option is specified, or the /tftpboot/boot/grub/menu.lst file. Typically, a single system is set up to serve both functions. In this instance, the add_install_client command sets up the /tftpboot file with the correct pxegrub menu file and the Oracle Solaris files. DHCP service is handled separately by using the add_install_client command. The setup only needs to be completed once per client. See x86: About DHCP Macros and x86: How to Perform a GRUB Based Boot From the Network for more information.
When you add clients with the add_install_client -d script on the install server, the script reports DHCP configuration information to standard output. You can use this information when you create the options and macros that are needed to pass network installation information to clients.
To install DHCP clients with a DHCP server over the network, you must create DHCP options. This information is needed to install the Oracle Solaris OS.
When a client sends a DHCP request, the server must have the following client information:
Client's ID, which is typically the Ethernet address
Class of the client request
Subnet on which the client resides
The DHCP server forms a response. This response is based on the following macros, which matches the client request:
The class macro is based on a class string that is contained in the DHCP request. On x86 based systems, the BIOS already makes a DHCP request with the class PXEClient:Arch:00000:UNDI:002001. If a macro by this name is defined in the DHCP server configuration, then the macro content is sent to the x86 based clients.
The network macro is named by the IP address of the subnet that the client resides on. If the macro 129.146.87.0 is defined on the DHPC server, the macro content is sent to all clients on that subnet. The macro content is sent, regardless of the class of the request. If an option is defined in both the class macro and the network macro, the network macro takes precedence.
The IP macro is named by an IP address. This macro is rarely used.
The client macro is named by the client type (01 for Ethernet) and the MAC address of the client, in uppercase letters. For a client with the Ethernet address 0:0:39:fc:f2:ef, the corresponding macro name is 01000039FCEF. Note the absence of colons in the client macro.
For example, for a client on the subnet 192.168.100.0, with the Ethernet address 0:0:39:fc:f2:ef, making a DHCP request of class PXEClient, the DHCP server has the following matching macro:
PXEClient BootSrvA: 192.168.100.0 BootFile: pxegrub 129.146.87.0 Router: 129.146.87.1 NISdmain: sunsoft.eng.sun.com 01000039FCEF BootFile: 01000039FCEF The actual DHCP response will be BootSrvA: 192.168.100.0 BootFile: 01000039FCEF Router: 129.146.87.1 NISdmain: sunsoft.eng.sun.com |
Note that the BootFile in the client macro overrides the BootFile in the class macro.
For more detailed information, see Preconfiguring System Configuration Information With the DHCP Service (Tasks) in Oracle Solaris 10 9/10 Installation Guide: Network-Based Installations.
To perform a GRUB based network boot, a DHCP server that is configured for PXE clients is required. A boot server that provides tftp service is also required. The DHCP server must be able respond to the DHCP classes, PXEClient and GRUBClient, to obtain the IP address of the file server and the boot file (pxegrub). By default, the menu file is /tftpboot/menu.lst.01ethernet-address. If this file does not exist, then pxegrub reverts to DHCP Option 150, if this option is specified, or the /tftpboot/boot/grub/menu.lst file.
If you are booting the system from the Solaris software media, the system boots automatically.
Before performing a network boot on an x86 based system with GRUB, do the following:
Run the appropriate commands on the installation server to enable the system to boot from the network.
Add the client system as an install client.
See Chapter 4, Installing From the Network (Overview), in Oracle Solaris 10 9/10 Installation Guide: Network-Based Installations for more information.
On the DHCP server, create a client macro for the DHCP service with the following two options:
BootSrvA: svr-addr
BootFile: client-macro
Note that you must have superuser privileges on the DHCP server to run the dhtadm command.
where svr-addr is the IP address of the server, and client-macro is named by the client's Ethernet type (01) and the MAC address, in uppercase letters. This number is also the name of the file that is used in the /tftpboot directory on the installation server.
The notation for the client-macro should not contain any colons.
You can create the client macro from the DHCP GUI or from command-line interface.
To create the client macro from the command-line, type:
# dhtadm -[MA] -m client macro -d ":BootFile=client-macro:BootSrvA=svr-addr:" |
Reboot the system.
Instruct the BIOS to boot from the network.
If your system uses a specific keystroke sequence to boot from the network, type the keystrokes when the BIOS screen is displayed.
If you need to manually modify the BIOS settings to boot from the network, type the keystroke sequence to access the BIOS setup utility. Then, modify the boot priority to boot from the network.
When the GRUB menu is displayed, select the network installation image that you want to install.
