System Administration Guide: Basic Administration
x86: Current Boot Parameters Menu
This menu appears each time you boot the Oracle Solaris release from the local disk. Let the five-second timeout elapse if you want to boot the default kernel. If you want to boot with different options, select an appropriate option before the timeout period elapses.
                     <<< Current Boot Parameters >>>
Boot path: /pci@0,0/pci-ide@7,1/ide@0/cmdk@0,0:a
Boot args:
Type    b [file-name] [boot-flags] <ENTER>       to boot with options
or      i <ENTER>                                to enter boot interpreter
or      <ENTER>                                  to boot with defaults
                     <<< timeout in 5 seconds >>>
Select (b)oot or (i)nterpreter:
