System Administration Guide: Basic Administration
Chapter 15 x86: GRUB Based Booting (Reference)
This chapter contains information about x86 boot processes, including GRUB implementation details and additional GRUB reference information.
For overview information, see Chapter 9, Shutting Down and Booting a System (Overview).
For step-by-step instructions on booting a system, see Chapter 12, Booting an Oracle Solaris System (Tasks).
x86: Boot Processes
This section includes information about boot processes that are unique to booting an x86 based system.
x86: System BIOS
When an x86 based system is powered on, it is controlled by the read-only-memory (ROM) Basic Input/Output System (BIOS). The BIOS is the firmware interface on Oracle Solaris operating systems that have x86 64-bit and 32-bit support.
Hardware adapters usually have an on-board BIOS that displays the physical characteristics of the device. The BIOS is used to access the device. During the startup process, the system BIOS checks for the presence of any adapter BIOS. If any adapters are found, the system then loads and executes each adapter BIOS. Each adapter's BIOS runs self-test diagnostics and then displays device information.
The BIOS on most systems has a user interface, where you can select an ordered list of boot devices that consists of the following selections:
The BIOS attempts to boot from each device, in turn, until a valid device with a bootable program is found.
x86: Kernel Initialization Process
The /platform/i86pc/multiboot program is an ELF32 executable that contains a header which is defined in the Multiboot Specification.
The multiboot program is responsible for performing the following tasks:
After the kernel gains control of the system, the kernel initializes the CPU, memory, and device subsystems. The kernel then mounts the root device, which corresponds to the bootpath and fstype properties that are specified in the /boot/solaris/bootenv.rc file. This file is part of the boot archive. If these properties are not specified in the bootenv.rc file, or on the GRUB command line, the root file system defaults to UFS on /devices/ramdisk:a. The root file system defaults to UFS when you boot the installation miniroot. After the root device is mounted, the kernel initializes the sched and init commands. These commands start the Service Management Facility (SMF) services.
x86: Support for GRUB in the Oracle Solaris OS
The following sections contain additional reference information for administering GRUB in the Oracle Solaris OS.
x86: GRUB Terminology
To thoroughly grasp GRUB concepts, an understanding of the following terms is essential.
Note –
Some of the terms that are described in this list are not exclusive to GRUB based booting.
boot archive
A collection of critical files that is used to boot the Oracle Solaris OS. These files are needed during system startup before the root file system is mounted. Multiple boot archives are maintained on a system:
  • A primary boot archive is used to boot the Oracle Solaris OS on an x86 based system.
  • A failsafe boot archive that is used for recovery when a primary boot archive is damaged. This boot archive starts the system without mounting the root file system. On the GRUB menu, this boot archive is called failsafe. The archive's primary purpose is to regenerate the primary boot archives, which are usually used to boot the system.
boot loader
The first software program that runs after you power on a system. This program begins the booting process.
failsafe archive
See boot archive.
GRUB
GNU GRand Unified Bootloader (GRUB) is an open-source boot loader with a menu interface. The menu displays a list of the operating systems that are installed on a system. GRUB enables you to easily boot these various operating systems, such as the Oracle Solaris OS, Linux, or Windows.
GRUB main menu
A boot menu that lists the operating systems that are installed on a system. From this menu, you can easily boot an operating system without modifying the BIOS or fdisk partition settings.
GRUB edit menu
A submenu of the GRUB main menu. GRUB commands are displayed on this submenu. These commands can be edited to change boot behavior.
menu.lst file
A configuration file that lists all the operating systems that are installed on a system. The contents of this file dictate the list of operating systems that is displayed in the GRUB menu. From the GRUB menu, you can easily boot an operating system without modifying the BIOS or fdisk partition settings.
miniroot
A minimal, bootable root (/) file system that resides on the Solaris installation media. A miniroot consists of the Solaris software that is required to install and upgrade systems. On x86 based systems, the miniroot is copied to the system to be used as the failsafe boot archive. See boot archive for details about the failsafe boot archive.
See boot archive.
x86: Functional Components of GRUB
GRUB consists of the following functional components:
You cannot use the dd command to write stage1 and stage2 images to disk. The stage1 image must be able to receive information about the location of the stage2 image that is on the disk. Use the installgrub command, which is the supported method for installing GRUB boot blocks.
Naming Conventions That Are Used for Configuring GRUB
GRUB uses device-naming conventions that are slightly different from previous Solaris releases. Understanding the GRUB device-naming conventions can assist you in correctly specifying drive and partition information when you configure GRUB on your system.
The following table describes the GRUB device-naming conventions for this Oracle Solaris release.
Table 15–1 Conventions for GRUB Devices
Device Name
Description
(fd0)
First diskette
(fd1)
Second diskette
(nd)
Network device
(hd0,0)
First fdisk partition on first hard disk
(hd0,1)
Second fdisk partition on first hard disk
(hd0,0,a),
Slice a on first fdisk partition on first hard disk
(hd0,0,b)
Slice b on first fdisk partition on first hard disk
Note –
All GRUB device names must be enclosed in parentheses.
For more information about fdisk partitions, see Guidelines for Creating an fdisk Partition in System Administration Guide: Devices and File Systems.
Naming Conventions That Are Used by the findroot Command
Starting with the Solaris 10 10/08 release, the findroot command replaces the root command that was previously used by GRUB. The findroot command provides enhanced capabilities for discovering a targeted disk, regardless of the boot device. The findroot command also supports booting from a ZFS root file system.
The following is a description of the device naming convention that is used by the findroot command for various GRUB implementations:
How Multiple Operating Systems Are Supported by GRUB
This section describes how multiple operating systems that are on the same disk are supported with GRUB. The following is an example of an x86 based system that has the Solaris 10 10/08 OS, the Solaris 9 OS, Linux, and Windows installed on the same disk.
Table 15–2 Sample GRUB Menu Configuration
Operating System
Location on Disk
Windows
fdisk partition 0
Linux
fdisk partition 1
Oracle Solaris
fdisk partition 2
Solaris 9 OS
Slice 0
Solaris 10 10/08 OS
Slice 3
Based on the preceding information, the GRUB menu would look like the following:
title Oracle Solaris 10
			findroot (pool_rpool,0,a)
			kernel$ /platform/i86pc/multiboot -B $ZFS-BOOTFS
			module /platform/i86pc/boot_archive
title Solaris 9 OS (pre-GRUB)
			root (hd0,2,a)
			chainloader +1
			makeactive
title Linux
			root (hd0,1)
			kernel <from Linux GRUB menu...>
			initrd <from Linux GRUB menu...>
title Windows
			root (hd0,0)
			chainloader +1
Note –
The Oracle Solaris slice must be the active partition. Also, do not indicate makeactive under the Windows menu. Doing so causes the system to boot Windows every time. Note that if Linux has installed GRUB on the master boot block, you cannot access the Oracle Solaris boot option. The inability to access the Solaris boot option occurs whether or not you designate it as the active partition.
In this case, you can do one of the following:
For information about the Oracle Solaris Live Upgrade boot environment, see Oracle Solaris 10 9/10 Installation Guide: Solaris Live Upgrade and Upgrade Planning.
x86: Supported GRUB Versions
In Oracle Solaris 10, GRUB uses multiboot. The contents of the menu.lst file vary, depending on the Oracle Solaris release you are running, the installation method that is used, and whether you are booting the system from an Oracle Solaris ZFS root or a UFS root.
Description of the menu.lst File (ZFS Support)
The following are various examples of a menu.lst file for a boot environment that contains a ZFS boot loader:
Note –
Because the miniroot is mounted as the real root file system, the entry for failsafe booting in the menu.lst file does not change to the ZFS bootfs property, even if the failsafe archive is read from a ZFS dataset. The ZFS dataset is not accessed after the boot loader reads the miniroot.
Example 15–1 Default menu.lst File (New Installation or Standard Upgrade)
title Solaris 10 5/08 s10x_nbu6wos_nightly X86
title Solaris failsafe
kernel /boot/multiboot kernel/unix -s    -B console=ttyb
module /boot/x86.miniroot-safe
Example 15–2 Default menu.lst File (Oracle Solaris Live Upgrade)
title be1
findroot (BE_be1,0,a)
bootfs rpool/ROOT/szboot_0508
title be1 failsafe
Description of the menu.lst File (UFS Support)
The following are examples of a menu.lst file on a system that supports booting from UFS.
Example 15–3 Default GRUB menu.lst File (New Installation or Standard Upgrade)
kernel /platform/i86pc/multiboot
findroot (rootfs0,0,a)
kernel /boot/multiboot kernel/unix -s -B console-ttyb
Example 15–4 Default GRUB menu.lst File (Oracle Solaris Live Upgrade)
title be1
title be1 failsafe
