System Administration Guide: Basic Administration
Managing Oracle Solaris Patches
This section describes how to manage Oracle Solaris patches with the patch tools that are available.
The patch tools do the following:
While you apply patches, the patchadd command logs information in the /var/sadm/patch/patch-id /log file.
Note –
Improvements have been made to the patchadd -M command. When you use this command to apply patches to your system, you are no longer required to specify patch IDs in numeric order. If you use the patchadd -M command without specifying a patch ID, all patches in the directory are installed on the system. For more information about these changes, see the patchadd(1M) man page.
The patchadd command cannot apply a patch or software update under the following conditions:
