The main source of documentation for using the console and its tools is the online help system. The following two forms of online help are available:
Context-sensitive help responds to your use of the console tools.
Clicking the cursor on tabs, entry fields, radio buttons, and so forth, causes the appropriate help to be displayed in the Information pane. You can close or reopen the Information pane by clicking the question mark button on dialog boxes and wizards.
Expanded help topics are available from the Help menu or by clicking cross reference links in some of the context-sensitive help.
These topics, which are displayed in a separate viewer, contain more in-depth information than is provided by the context help. Topics include: overviews of each tool, explanations of how each tool works, files that are used by a specific tool, and troubleshooting information.
For a brief overview of each tool, refer to Table 2–1.
