Task |
Description |
For Instructions |
Start applications from the Oracle Java Web Console's launch page. |
The Oracle Java Web Console's launch page lists all of the registered system management applications that you have permission to use. You connect to a specific application by clicking its application name. |
How to Start Applications From the Oracle Java Web Console's Launch Page |
Start, stop, enable, and disable the console server. |
You can manage the web server that is used to run the console and the registered applications. |
How to Start the Console Service How to Enable the Console Service to Run at System Start |
Change the Oracle Java Web Console's properties. |
You should not have to change any of the web console's default properties. Properties that you might choose to change include the following:
