You can use Oracle Solaris Product Registry to find software and launch the installation GUI program. This program takes you through the installation of that software.
Become superuser or assume an equivalent role.
Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
Start the Oracle Solaris Product Registry tool.
# prodreg |
The Oracle Solaris Product Registry main window is displayed.
Depending on whether you are installing from a CD, a DVD, or from the network, do one of the following:
If you running a release that uses CDs, insert the CD into the CD-ROM drive.
If you are installing from a DVD, insert the DVD into the DVD-ROM drive.
If you are installing from the network, locate the net image of the software that you want to install.
In this Oracle Solaris release, the software is delivered on DVD only.
To view the list of installed and registered software, click the turner control.
Click the New Install button at the bottom of the Oracle Solaris Product Registry window.
The Select Installer dialog box is displayed. This box initially points to the /cdrom directory or the directory you are in.
Select directories to find the Oracle Solaris installation GUI installer.
Oracle Solaris installation GUI installers are located in various directories on the CDs and on the DVD.
Solaris 10 Software CDs or DVD.
Solaris 10 Documentation DVD.
Solaris 10 Languages CD. The installation GUI automatically starts when the CD is inserted.
When you find the installer you want, select its name in the Files box.
Click OK.
The installer you selected is launched.
Follow the directions that are displayed by the installer to install the software.
