System Administration Guide: Basic Administration
ProcedureHow to Uninstall Damaged Software (prodreg )
If you try to uninstall a damaged software component by using the prodreg uninstall command, the command might fail. This failure can occur if the uninstaller program for the software component has been removed from the system.
Follow these steps to uninstall a software component with no associated uninstaller program on the system.
  1. Become superuser or assume an equivalent role.
    Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
  2. View the information on the software you want to uninstall.
    # prodreg browse -m "name"
  3. Uninstall the software.
    # prodreg uninstall -u UUID -i 1
  4. Identify the uninstaller program for the software component.
    # prodreg info -m "name" -a uninstallprogram
  5. Determine if the uninstaller is in the registered location.
    # ls uninstaller-location uninstaller-location
  6. Remove the software from the system in one of the following ways:
    • If you have a system backup available, follow these steps:
      1. Load the uninstaller program from the backup.
      2. Run the uninstaller program from a shell command-line interface such as a terminal window.
    • If you do not have access to the uninstaller program on a backup, follow these steps:
      1. Unregister the software component.
        # prodreg unregister -u UUID -i 1
      2. Remove any remaining registered components that are required by the software you want to remove.
        # pkgrm component-a-UUID
Example 21–10 Uninstalling Damaged Software (prodreg)
The following example shows how to uninstall the damaged ExampleSoft software. In this example, the uninstaller program is not readily available on a system backup.
# prodreg browse -m Examplesoft
BROWSE #  +/-/.  UUID                                  #  NAME
1         -      root                                  1  System
2          +     a01ee8dd-1dd1-11b2-a3f2-0800209a5b6b  1  Solaris 10
3          +     8f64eabf-1dd2-11b2-a3f1-0800209a5b6b  1  Unclassified
4          -     95842091-725a-8501-ef29-0472985982be  1  ExampleSoft
233         .    90209809-9785-b89e-c821-0472985982be  1  Example Doc
234         .    EXSOzzt                               1
235         .    EXSOblob                              1  Example Data
# prodreg uninstall -u 95842091-725a-8501-ef29-0472985982be -i 1
The install program requested could not be found
# prodreg info -m "ExampleSoft" -a uninstallprogram
uninstallprogram: /usr/bin/java -mx64m -classpath
/var/sadm/prod/org.example.ExampleSoft/987573587 uninstall_ExampleSoft
# ls /var/sadm/prod/org.example.ExampleSoft/987573587
No such file or directory
# prodreg unregister -u 95842091-725a-8501-ef29-0472985982be -i 1
# pkgrm EXSOblob
