Become superuser or assume an equivalent role.
Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
Create a skeleton directory for each type of user.
# mkdir /shared-dir/skel/user-type |
The name of a directory that is available to other systems on the network.
The name of a directory to store initialization files for a type of user.
Copy the default user initialization files into the directories that you created for different types of users.
# cp /etc/skel/local.cshrc /shared-dir/skel/user-type/.cshrc # cp /etc/skel/local.login /shared-dir/skel/user-type/.login # cp /etc/skel/local.profile /shared-dir/skel/user-type/.profile |
If the account has profiles assigned to it, then the user has to launch a special version of the shell called a profile shell to use commands (with any security attributes) that are assigned to the profile. There are three profile shells corresponding to the types of shells: pfsh (Bourne shell), pfcsh (C shell), and pfksh (Korn shell). For information about profile shells, see Role-Based Access Control (Overview) in System Administration Guide: Security Services.
Edit the user initialization files for each user type and customize them based on your site's needs.
For a detailed description on the ways to customize the user initialization files, see Customizing a User's Work Environment.
Set the permissions for the user initialization files.
# chmod 744 /shared-dir/skel/user-type/.* |
Verify that the permissions for the user initialization files are correct.
# ls -la /shared-dir/skel/* |
The following example shows how to customize the C-shell user initialization file in the /export/skel/enduser directory designated for a particular type of user. For an example of a .cshrc file, see Example 4–3.
# mkdir /export/skel/enduser # cp /etc/skel/local.cshrc /export/skel/enduser/.cshrc (Edit .cshrc file) # chmod 744 /export/skel/enduser/.* |
