System Administration Guide: Basic Administration
ProcedureHow to Delete a User Account
Use the following procedure to remove a user account.
  1. Become superuser or assume an equivalent role.
    Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
  2. Start the Solaris Management Console.
    # /usr/sadm/bin/smc &
    For more information on starting the Solaris Management Console, see How to Start the Console as Superuser or as a Role or How to Start the Solaris Management Console in a Name Service Environment.
  3. Click the This Computer icon under the Management Tools icon in the Navigation pane.
    A list of categories is displayed.
  4. (Optional) Select the appropriate toolbox for your name service environment.
  5. Click the System Configuration icon.
  6. Click the User icon.
  7. Provide the superuser password or the role password.
  8. Click the User Accounts icon.
  9. Double–click the user account to be removed.
    For example, select scutter4.
  10. Click Delete in the pop-up window if you are sure you want to remove the user account.
    You are prompted to remove the user's home directory and mailbox contents.
