International Language Environments Guide
XmRendition Resource
CTL adds the new pseudo resources listed in the following table to XmRendition. Descriptions of the pseudo resources follow the table.
Table 6–1 New Resources in XmRendition
Name
Class/Type
Access
Default Value
XmNfontType
XmCFontType/XmFontType
CSG
XmAS_IS
XmNlayoutAttrObject
XmClayoutAttrObject/String
CG
NULL
XmNlayoutModifier
XmClayoutModifier/String
CSG
NULL
XmNfontType
Specifies the type of the Rendition font object. For CTL, the value of this resource must be the XmFONT_IS_XOC value. If the value does not match, then the XmNlayoutAttrObject and XmNlayoutModifier resources are ignored.
When the value of this resource is XmFont_IS_XOC and the XmNfont resource is not specified, then at create time the value of the XmNfontName resource is converted into an XOC object in either the locale specified by the XmNlayoutAttrObject resource or the current locale. Furthermore, the value of the XmNlayoutModifier resource is passed through to any layout object associated with the XOC.
XmNlayoutAttrObject
Specifies the layout AttrObject argument. This resource is used to create the layout object associated with the XOC associated with this XmRendition. Refer to the layout services m_create_layout() specification for the syntax and semantics of this string. See the description of XmNfontType for an explanation of the interaction between the Layout Modifier Orientation output value and the XmNlayoutDirection widget resource.
XmNlayoutModifier
Specifies the layout values to be passed through to the layout object used with the XOC for this XmRendition. For the syntax and semantics of this string, see CAE Specification.
Setting this resource using XmRendition{Retrieve,Update} causes the string to be passed through to the layout object associated with the XOC associated with this rendition. This mechanism enables you to configure layout services dynamically. Unpredictable behavior can result if the Orientation, Context, TypeOfText, TextShaping, or ShapeCharset are changed.
Additional Layout Behavior
The XmNlayoutModifier affects the layout behavior of the text associated with the XmRendition. For example, if the layout default treatment of numerals is NUMERALS_NOMINAL, you change to NUMERALS_NATIONAL by setting XmNlayoutModifier to @ls numerals=nominal:national, or @ls numerals=:national.
The layout values can be classified into the following groups:
