Korean Solaris User's Guide
How to Verify TTY Set Up
Use the following procedure to verify that the TTY is properly set up.
  1. Type the /bin/stty command with the -a option.
    system% /bin/stty -a
  2. If the cs8, -istrip values set in the previous procedure are not listed, use the following command to set them.
    system% /bin/stty cs8 -istrip defeucw
This is the last step in setting up a terminal. The default setting of a Korean terminal is the completion-code mode. Continue to the next section to install a Packed-code TTY.
