The following are extensions to terminfo. The s0-s3 string values are used as data announcement mechanisms for the respective code sets during terminal I/O.
Table 12–3 terminfo Variables and Definitions
Variable |
Capname |
Tc |
Definition |
device_type |
devt |
dv |
Device type: language and code set |
code_set_init |
csin |
ci |
Init sequence for multiple code sets |
set0_des_set |
s0ds |
s0 |
Shift into code set 0 |
set1_des_set |
s1ds |
s1 |
Shift into code set 1 |
set2_des_set |
s2ds |
s2 |
Shift into code set 2 |
set3_des_set |
s3ds |
s3 |
Shift into code set 3 |
