You can enter any character defined in a character set supported for a locale by typing the encoding value of the character.
In the ko_KR.EUC locale, you can use the KS X 1001 encoding values to enter the characters that are defined in the character set.
In the ko_KR.UTF-8 locale, you can use the encoding values that are defined in the following character sets to input the characters of each set.
KS X 1001, known as KS C 5601–1987
UTF-8 encoded values from Unicode 3.2
The following table shows you the key sequences you can use to select character sets in each locale.
Current Locale |
Key Sequence |
Character Set |
ko_KR.EUC |
Control-X |
KS X 1001 |
ko_KR.UTF-8 |
Control-X |
KS X 1001 |
ko_KR.UTF-8 |
Control-Shift-X |
UTF-8 |
Press Control-spacebar to turn on Hangul input conversion.
Press Control-X to turn on hex mode in the ko_KR.EUC locale or the ko_KR.UTF-8 locale.
Alternatively, you can select the hex input mode from the palette auxiliary window.
The status area indicates that you are in hex input mode and that you can use KS X encoding values to input Hangul characters.
The palette window changes to indicate that you are in hex mode.
The only keys that are available in hex mode are the letters a through f, the numbers 0 through 9, and the Delete key. You can also use Control-X to exit hex mode.
The Control-X option appears in this procedure to access the KS X 1001 character set for example purposes. You can press Control-Shift-X to enter a hex code from the UTF-8 character set.
Type the first three keys of the hex code for the character. For example, you could type a2d in the preedit area as shown in the following figure.
Type the last key of the hex code to display and to automatically commit the character. For example, if you type d in the preedit area, the glyph for two notes of music appears.
Press Control-X to turn off hex mode.
