Use the Options Auxiliary window to save your preference settings and to make the preferences available by default. To launch this window, click the Utilities button on the Palette Auxiliary window and select the Input Method Property Configuration menu.
The Options Auxiliary window appears.
You can specify the following options the Options Auxiliary window:
2 Beol Sik
3 Beol Sik 390
3 Beol Sik final
Default Hangul to Hanja conversion format
Hangul to Hanja
Hanja to Hangul (Hanja)
Hanja to Hangul (Hangul)
Automatic commit on a character basis
The option enables you to commit a character in the preedit buffer as soon as you completely enter the character.
Automatic commit on a single-candidate conversion
This option enables you to automatically commit Hanja when only a single candidate is available for the characters you want to convert.
