The following routines perform character-based code conversion on the KS C 5601 character set. They convert characters in the set between Completion code (or EUC format) and Combination code (or Packed code). To use these routines, the library kle must be linked using the C compiler option -lkle. For more information, see the kconv(3x) man page.
Table A–2 Korean Code Conversion Functions
Function |
Description |
comptopack() |
Converts a character in Completion code to Combination (packed) code of KS C 5601-1987. |
packtocomp() |
Converts a character in Combination (Packed) code of KS C 5601-1987 to Completion code. |
wasuntojohap() |
Converts a character in Completion code to Combination (Packed) code of KS C 5601-1992. |
packtocomp() |
Converts a character in Combination (Packed) code of KS C 5601-1992 to Completion code. |
