Korean Solaris User's Guide
Setting the Default Locale
You can use the procedure in this section to make a system-wide change to the default locale.
How to Set the Default Locale
  1. Become superuser.
  2. Edit the /etc/default/init file.
  3. Add or update the LANG variable with the appropriate locale.
    C, ko, or the ko.UTF-8
  4. Instruct all users to exit CDE.
  5. Kill the dtconfig process.
    # /usr/dt/bin/dtconfig -kill
  6. Reboot the system.
    # reboot
