Simplified Chinese Solaris User's Guide
Chapter 5 Localized Applications
The following sections in this chapter describe the utilities and applications that you use in the Simplified Chinese Solaris Operating System.
stdconvtool Utility
The sdtconvtool graphic user interface utility enables file conversion between various code sets. The sdtconvtool functionality is similar to iconv.
The following figure shows the stdconvtool panel.
The preceding context describes the graphic.
How to Convert a File Using the stdconvtool Utility
  1. Select the code set of the file to be converted.
    Scroll through the pull-down list and select the code set of the file to be converted.
  2. Enter the path of the file to be converted.
    You can enter the path manually in the source file path area, or you can use the browse button to find and select the file.
  3. Select the code set to for the converted file.
    Select the target code set.
  4. Enter the path for the target file.
    You can enter the path manually in the target file path area, or you can use the browse button to find and select the file.
  5. Click the start conversion button.
iconv Command
The iconv command converts the characters or sequences of characters in a file from one code set to another. The command then writes the results to standard output. The Simplified Chinese Solaris software includes special filters for the iconv command.
If no conversion exists for a particular character, the character is converted to the underscore _ in the target code set. The following options are supported:
The following table lists the code set conversion modules that are supported in Simplified Chinese Solaris software. For more information, see Solaris 10 Reference Manual Collectioniconv(1).
Table 5–1 Simplified Chinese iconv Code Conversion Modules (zh locale)
Code
Symbol
Target Code
Symbol
ISO2022–CN
zh_CN.iso2022–CN
UTF–8
UTF–8
UTF–8
UTF–8
ISO2022-CN
zh_CN.iso2022–CN
zh.GBK
zh_CN.gbk
ISO2022-CN
zh_CN.iso2022–CN
zh.GBK
zh_CN.gbk
UTF–8
UTF–8
GB2312-80
zh_CN.euc
ISO 2022-7
zh_CN.iso2022-7
ISO 2022-7
zh_CN.iso2022-7
GB2312-80
zh_CN.euc
GB2312-80
zh_CN.euc
ISO 2022-CN
zh_CN.iso2022-CN
ISO-2022-CN
zh_CN.iso2022-CN
GB2312-80
zh_CN.euc
UTF-8
UTF-8
GB2312-80
zh_CN.euc
GB2312-80
zh_CN.euc
UTF-8
UTF-8
GB2312-80
zh_CN.euc
BIG5
zh_TW-big5
BIG5
zh_TW.big5
GB2312-80
zh_CN.euc
HZ-GB-2312
HZ-GB-2312
GB2312–80
zh_CN.euc
GB2312–80
zh_CN.euc
HZ-GB-2312
zh_CN.euc
Table 5–2 Simplified Chinese iconv Code Conversion Modules (zh.GBK locale)
Code
Symbol
Target Code
Symbol
UTF-8
UTF-8
GBK
zh_CN.gbk
GBK
zh_CN.gbk
UTF-8
UTF-8
GBK
zh_CN.gbk
BIG5P
zh_TW-big5p
GBK
zh_CN.gbk
BIG5HK
zh_TW-big5hk
GBK
zh_CN.gbk
ISO-2022-CN
zh_CN.iso2022-CN
ISO2022-CN
zh_CN.iso2022-CN
GBK
zh_CN.gbk
GBK
zh_CN.gbk
BIG5
zh_TW-big5
BIG5
zh_TW-big5
GBK
zh_CN.gbk
BIG5P
zh_TW-big5p
GBK
zh_CN.gbk
BIG5HK
zh_TW-big5hk
GBK
zh_CN.gbk
HZ-GB-2312
HZ-GB-2312
GBK
zh_CN.gbk
GBK
zh_CN.gbk
HZ-GB-2312
zh_CN.gbk
HZ-GB-2312
HZ-GB-2312
UTF-8
UTF-8
UTF-8
UTF-8
HZ-GB-2312
HZ-GB-2312
Table 5–3 Simplified Chinese iconv Code Conversion Modules (zh_CN.GB18030 locale)
Code
Symbol
Target Code
Symbol
UTF-8
UTF-8
GB18030-2000
zh_CN.gb18030
GB18030-2000
zh_CN.gb18030
UTF-8
UTF-8
GB18030-2000
zh_CN.gb18030
BIG5HK
zh_HK-big5hk
GB18030-2000
zh_CN.gb18030
BIG5P
zh_TW-big5p
BIG5HK
zh_HK-big5hk
GB18030-2000
zh_CN.gb18030
BIG5P
zh_TW-big5p
GB18030-2000
zh_CN.gb18030
The following iconv code conversion modules are located in /usr/lib/iconv:
For the zh locale:
For the zh.GBK locale:
In the following example, an EUC mail file is converted to ISO 2022-CN:
system% iconv -f zh_CN.euc -t zh_CN.iso2022-CN mail.euc > mail.iso2022-CN
For further information, see the iconv(3C) and the iconv_zh(5) man pages. These utilities can be used for converting files for printing.
