Traditional Chinese Solaris User's Guide
Appendix A Binary Compatibility Package
Applications compiled under Chinese OpenWindowsTM 2.x or Solaris 1.x or SunOS 4.x systems have different binary formats than the current Chinese Solaris release. Older applications can nevertheless be run under the current Chinese release without being recompiled by using the application's included binary compatibility package (BCP).
Note –
SUNWowbcp must be included in your system configuration in order to run the following commands. See your system administrator for installation.
The following BCP command runs the compiled binary code of earlier SunOS4.x, Solaris 1.x, or Chinese OpenWindows 2.x applications without recompilation, However, OpenWindows V2 Chinese applications will display no input server status region. As shown in the following examples, the command calls the application by its old name (old_application_name) and sets the basic locale, input language, and display language using the older version's specific locale name (old-locale):
system% old_application_name -lc_basiclocale
old-locale -lc_inputlang old-locale
\ -lc_displaylang old-locale
The following example shows the command you use to run the compiled binary code of an earlier version of the textedit application on the current Traditional Chinese Solaris Operating System:
system% textedit -lc_displaylang tchinese -lc_basiclocale tchinese \
    -lc_inputlang tchinese
Due to incompatibilities between Traditional Chinese Solaris 2.x and 1.x applications, you cannot cut and paste Chinese characters between them.
Traditional Chinese Test Utilities
Every utility listed in this section is supported, but for this version of Solaris, you are encouraged to use the XPG4 internationalization APIs as described in the International Language Environments Guide.
The utilities in the following table test various aspects of the Traditional Chinese (CNS 11643) national standard character set. These utilities also assume that the character being tested is part of the national standard character set. Each utility returns true if the character meets the test requirement referenced in the description.
The arguments for the functions in the following table must be characters in wide character code (WC), wchar_t. For more information, see Asian-Specific Utilities and the hctype(3x) man page.
Table A–1 Traditional Chinese Test Utilities
Utility
Description
ishalpha
Tests for a Roman character in the CNS 11643 character set.
ishupper
Tests for an uppercase Roman character as defined by the CNS 11643 character set.
ishlower
Tests for a lowercase Roman character in the CNS 11643 character set.
ishdigit
Tests for a number in the CNS 11643 character set.
ishspace
Tests for the space character in the CNS 11643 character set.
ishpunct
Tests for a punctuation character in the CNS 11643 character set.
ishparen
Tests for a left or right parenthesis in the CNS 11643 character set.
ishphontone
Tests for a Mandarin phonetic tone.
ishradical
Tests for a Chinese character radical.
ishline
Tests for a ruled line symbol in the CNS 11643 character set.
ishunit
Tests for a unit character in the CNS 11643 character set.
ishsci
Tests for a scientific symbol in the CNS 11643 character set.
ishgen
Tests for a general symbol in the CNS 11643 character set.
ishgreek
Tests for a Greek character in the CNS 11643 character set.
This section describes functions for wide character and string input and output, character classification, and conversion functions for the Korean or Chinese character sets. Asian Solaris software implements a wide character library for handling Korean or Chinese character codes according to industry standards.
Routines that have Korean or Chinese language-specific dependency are in their own language-specific library, which is linked with the corresponding C compiler option. In the Traditional Chinese Solaris software, libhle is linked with -lhle. Refer to the appropriate man page for more information.
Asian Solaris software defines WC as a constant-width, four-byte code. WC uses the ANSI C data type wchar_t, which Solaris software defines in wchar.h as follows:
typedef long wchar_h;
In Solaris software, long is four bytes.
Conversion Utilities
The conversion utilities described in this section are available, but you should use iconv as a standard function.
Asian Solaris software provides facilities for various conversions, for example:
Programs using the general multibyte conversion utilities should include the header files widec.h and wctype.h. Traditional Chinese Solaris routines (such as ishxxx) are declared in zh_TW/xctype.h.
Programs using the general multibyte conversion utilities should include three header files: wctype.h, widec.h, and zh_TW/xctype.h.
As with classification functions described in the previous section, the use of these utilities can be controlled by the setlocale function. Locale-specific routines are contained in a locale-specific library. For Traditional Chinese, that library is libhle. The library can be linked during compilation using the C compiler option -lhle.
Conversion Within a Code Set
The multibyte conversion functions are similar to the one-byte conversion functions toupper() and tolower(). These functions convert wide-characters to other wide characters. For more information on conversion routines, see the man pages for wconv(3) for all locales and hconv(3) for Traditional Chinese.
The routines listed in the following table are in the regular Chinese C library:
Table A–2 Chinese C Library Conversion Routines
Function
Description
tohupper()
Converts code set 1 Roman lowercase to uppercase
tohlower()
Converts code set 1 Roman uppercase to lowercase
Conversion for Traditional Chinese Character Codes
The routines listed in the following table perform character-based code conversion on the CNS-11643 character set. They convert characters in the set between CNS-11643, EUC, and Big5 formats. To use these routines, the library hle must be linked using the C compiler option -lhle. For more information, see the hconv(3x) man page.
Table A–3 Character-Based Code Conversion Routines
Function
Description
cbig5toeuc()
Converts BIG5 character to EUC
ccnstoeuc()
Converts CNS character to EUC
ceuctobig5()
Converts EUC character to BIG5
ceuctocns()
Converts EUC character to CNS
Table A–4 Character-Based Code Conversion Routines (cont)
Function
Description
big5toeuc()
Converts BIG5 string to EUC.
cnstoeuc()
Converts CNS string to EUC.
euctobig5()
Converts EUC string to BIG5.
euctocns()
Converts EUC string to CNS.
