Traditional Chinese Solaris User's Guide
How to Search and Select Lookup Choices
  1. Type a string you want to convert in the preedit area.
    The lookup choice window appears.
    You can use the following keys to search through the characters and radicals that are available for your string.
    Period (.)
    Moves forward to the next page of choices
    Comma (,)
    Moves backward through the choices
  2. Type the number or letter of the label of the lookup choice you want to select.
    Your choice is substituted for the string in the preedit area.
