Solaris System Management Agent Developer's Guide
Appendix B MIBs Implemented in SMA
This appendix lists some of the MIBs that are implemented in the System Management Agent.
This list includes the MIB modules that have been built into the agent.
UCD-DISKIO-MIB
MIB module for disk IO statistics
RFC1213-MIB
MIB II groups, including IP, TCP, UDP, SYSTEM, ICMP, SNMP, INTERFACES, and STATISTICS. The EGP group is not implemented.
UCD-SNMP-MIB
Memory usage, watch reporting, load averages, virtual memory statistics.
SNMP-USER-BASED-SM-MIB
SNMPv3 user model, security statistics, authentication key information, privacy protocols, USM storage types.
SNMP-VIEW-BASED-ACM-MIB
Group names and access views for View-based Access Control Model (VACM).
UCD-DLMOD-MIB
Names of dynamically loadable modules, location of module, status, dynamic load and unload state.
NET-SNMP-AGENT-MIB
Defines control and monitoring structures for the Net-SNMP agent, gives OIDs and timeout values of all SNMP registered with the agent.
DISMAN-EVENT-MIB
Allows triggering of events and actions for management purposes. The Management Agent for Sun Fire servers uses this MIB.
HOST-RESOURCES-MIB
This MIB is for use in managing host systems. A host in this context is a computer that is used by one or more people. The computer communicates with other similar computers that are attached to the network. The Host Resources MIB does not necessarily apply to devices such as terminal servers, routers, bridges, and monitoring equipment, whose primary function is communications services. However, these types of communication devices are not explicitly precluded from being managed with this MIB. The Host Resources MIB defines attributes that are common to all Internet hosts including, for example, both personal computers and UNIX systems. The MIB also provides Solaris kernel statistics.
SNMP-NOTIFICATION-MIB
The SNMP-NOTIFICATION-MIB module defines MIB objects that provide mechanisms to remotely configure notification parameters. These parameters are used by an SNMP entity for the generation of notifications, or traps.
SUN-SEA-EXTENSIONS-MIB
The SUN-SEA-EXTENSIONS-MIB module describes the Sun-specific extensions to MIB-II.
SUN-SEA-PROXY-MIB
The SUN-SEA-PROXY-MIB is used to manage the Solstice Enterprise Agents snmpdx master agent daemon.
AGENTX-MIB
The AGENTX-MIB module is used for the SNMP Agent Extensibility Protocol, AgentX. This MIB module is implemented by the master agent but must be explicitly enabled in order to be used.
