Programming Interfaces Guide
Setting a File Lock
To lock an entire file, set the offset to zero and set the size to zero.
You can set a lock on a file in several ways. The choice of method depends on how the lock interacts with the rest of the program, performance, and portability. This example uses the POSIX standard-compatible fcntl(2) interface. The interface tries to lock a file until one of the following happens:
