Programming Interfaces Guide
Basic File I/O
The following interfaces perform basic operations on files and on character I/O devices.
Table 6–1 Basic File I/O Interfaces
Interface Name
Open a file for reading or writing
Close a file descriptor
Read from a file
Write to a file
Create a new file or rewrite an existing one
Remove a directory entry
Move read/write file pointer
The following code sample demonstrates the use of the basic file I/O interface. read(2) and write(2) both transfer no more than the specified number of bytes, starting at the current offset into the file. The number of bytes actually transferred is returned. The end of a file is indicated on a read(2) by a return value of zero.
Example 6–1 Basic File I/O Interface
#include			<fcntl.h>
#define			MAXSIZE			256
    int     fd;
    ssize_t n;
    char	    array[MAXSIZE];
    fd = open ("/etc/motd", O_RDONLY);
    if (fd == -1) {
        perror ("open");
        exit (1);
    while ((n = read (fd, array, MAXSIZE)) > 0)
        if (write (1, array, n) != n)
            perror ("write");
    if (n == -1)
        perror ("read");
    close (fd);
When you are done reading or writing a file, always call close(2). Do not call close(2) for a file descriptor that was not returned from a call to open(2).
File pointer offsets into an open file are changed by using read(2), write(2), or by calls to lseek(2). The following example demonstrates the uses of lseek.
off_t     start, n;
struct    record    rec;
/* record current offset in start */
start = lseek (fd, 0L, SEEK_CUR);
/* go back to start */
n = lseek (fd, -start, SEEK_SET);
read (fd, &rec, sizeof (rec));
/* rewrite previous record */
n = lseek (fd, -sizeof (rec), SEEK_CUR);
write (fd, (char *&rec, sizeof (rec));
