Programming Interfaces Guide
Memory Segment Publish, Republish, and Unpublish
The publish operation enables the importing of a memory segment by other nodes on the interconnect. An export segment might be published on multiple interconnect adapters.
The segment ID might be specified from within authorized ranges or specified as zero, in which case a valid segment ID is generated by the RSMAPI framework and is passed back.
The segment access control list is composed of pairs of node ID and access permissions. For each node ID specified in the list, the associated read/write permissions are provided by three octal digits for owner, group and other, as with Solaris file permissions. In the access control list, each octal digit can have the following values:
2
Write access.
4
Read only access.
6
Read and write access.
An access permission value of 0624 specifies the following kind of access:
When an access control list is provided, nodes not included in the list cannot import the segment. However, if the access list is null, any node can import the segment. The access permissions on all nodes equal the owner-group-other file creation permissions of the exporting process.
Note –
Node applications have the responsibility of managing the assignment of segment identifiers to ensure uniqueness on the exporting node.
Publish Segment
int rsm_memseg_export_publish(rsm_memseg_export_handle_t memseg, rsm_memseg_id_t *segment_id, rsmapi_access_entry_t ACCESS_list[], uint_t access_list_length);
typedef struct {
    rsm_node_id_t       ae_node;    /* remote node id allowed to access resource */
    rsm_permission_t    ae_permissions;    /* mode of access allowed */
} rsmapi_access_entry_t;.
Return Values: Returns 0 if successful. Returns an error value otherwise.
RSMERR_BAD_SEG_HNDL
Invalid segment handle
RSMERR_SEG_ALREADY_PUBLISHED
Segment already published
RSMERR_BAD_ACL
Invalid access control list
RSMERR_BAD_SEGID
Invalid segment identifier
RSMERR_SEGID_IN_USE
Segment identifier in use
RSMERR_RESERVED_SEGID
Segment identifier reserved
RSMERR_NOT_CREATOR
Not creator of segment
RSMERR_BAD_ADDR
Bad address
RSMERR_INSUFFICIENT_MEM
Insufficient memory
RSMERR_INSUFFICIENT_RESOURCES
Insufficient resources
Authorized Segment ID Ranges:
#define RSM_DRIVER_PRIVATE_ID_BASE
0
#define RSM_DRIVER_PRIVATE_ID_END
0x0FFFFF
#define RSM_CLUSTER_TRANSPORT_ID_BASE
0x100000
#define RSM_CLUSTER_TRANSPORT_ID_END
0x1FFFFF
#define RSM_RSMLIB_ID_BASE
0x200000
#define RSM_RSMLIB_ID_END
0x2FFFFF
#define RSM_DLPI_ID_BASE
0x300000
#define RSM_DLPI_ID_END
0x3FFFFF
#define RSM_HPC_ID_BASE
0x400000
#define RSM_HPC_ID_END
0x4FFFFF
The following range is reserved for allocation by the system when the publish value is zero.
#define RSM_USER_APP_ID_BASE
0x80000000
#define RSM_USER_APP_ID_END
0xFFFFFFF
Republish Segment
int rsm_memseg_export_republish(rsm_memseg_export_handle_t memseg, rsmapi_access_entry_t access_list[], uint_t access_list_length);
This function establishes a new node access list and segment access mode. These changes only affect future import calls and do not revoke already granted import requests.
RSMERR_BAD_SEG_HNDL
RSMERR_SEG_NOT_PUBLISHED
Segment not published
RSMERR_BAD_ACL
RSMERR_NOT_CREATOR
RSMERR_INSUFFICIENT_MEMF
Insufficient memory
RSMERR_INTERRUPTED
Operation interrupted by signal
Unpublish Segment
int rsm_memseg_export_unpublish(rsm_memseg_export_handle_t memseg);
RSMERR_BAD_SEG_HNDL
RSMERR_NOT_CREATOR
RSMERR_INTERRUPTED
