Programming Interfaces Guide
Memory Segment Connection and Disconnection
Connect to Segment
int rsm_memseg_import_connect(rsmapi_controller_handle_t controller, rsm_node_id_t node_id, rsm_memseg_id_t segment_id, rsm_permission_t perm, rsm_memseg_import_handle_t *im_memseg);
This function connects to segment segment_id on remote node node_id by using the specified permission perm. The function returns a segment handle after connecting to the segment.
The argument perm specifies the access mode requested by the importer for this connection. To establish the connection, the access permissions specified by the exporter are compared to the access mode, user ID, and group ID used by the importer. If the request mode is not valid, the connection request is denied. The perm argument is limited to the following octal values:
0400
Read mode
0200
Write mode
0600
Read/write mode
The specified controller must have a physical connection to the controller that is used in the export of the segment.
Return Values: Returns 0 if successful. Returns an error value otherwise.
RSMERR_BAD_CTLR_HNDL
Invalid controller handle
RSMERR_CTLR_NOT_PRESENT
Controller not present
RSMERR_BAD_SEG_HNDL
Invalid segment handle
RSMERR_PERM_DENIED
Permission denied
RSMERR_SEG_NOT_PUBLISHED_TO_NODE
Segment not published to node
No such segment published
RSMERR_REMOTE_NODE_UNREACHABLE
Remote node not reachable
RSMERR_INTERRUPTED
Connection interrupted
RSMERR_INSUFFICIENT_MEM
Insufficient memory
RSMERR_INSUFFICIENT_RESOURCES
Insufficient resources
RSMERR_BAD_ADDR
Bad address
Disconnect from Segment
int rsm_memseg_import_disconnect(rsm_memseg_import_handle_t im_memseg);
This function disconnects a segment. This function frees a segment's resources after disconnecting a segment. All existing mappings to the disconnected segment are removed. The handle im_memseg is freed.
RSMERR_BAD_SEG_HNDL
RSMERR_SEG_STILL_MAPPED
Segment still mapped
RSMERR_POLLFD_IN_USE
pollfd in use
