Programming Interfaces Guide
Segment Mapping
Mapping operations are only available for native architecture interconnects such as Dolphin-SCI or NewLink. Mapping a segment grants CPU memory operations access to that segment, saving the overhead of calling memory access primitives.
Imported Segment Map
int rsm_memseg_import_map(rsm_memseg_import_handle_t im_memseg, void **address, rsm_attribute_t attr, rsm_permission_t perm, off_t offset, size_t length);
This function maps an imported segment into the caller address space. If the attribute RSM_MAP_FIXED is specified, the function maps the segment at the value specified in **address.
typedef enum {
    RSM_MAP_NONE  = 0x0,    /* system will choose available virtual address */
    RSM_MAP_FIXED = 0x1,    /* map segment at specified virtual address */
} rsm_map_attr_t;
Return Values: Returns 0 if successful. Returns an error value otherwise.
RSMERR_BAD_SEG_HNDL
Invalid segment handle
RSMERR_BAD_ADDR
Invalid address
RSMERR_BAD_LENGTH
Invalid length
RSMERR_BAD_OFFSET
Invalid offset
RSMERR_BAD_PERMS
Invalid permissions
RSMERR_SEG_ALREADY_MAPPED
Segment already mapped
RSMERR_SEG_NOT_CONNECTED
Segment not connected
RSMERR_CONN_ABORTED
Connection aborted
RSMERR_MAP_FAILED
Error during mapping
RSMERR_BAD_MEM_ALIGNMENT
Address not aligned on page boundary
Unmap segment
int rsm_memseg_import_unmap(rsm_memseg_import_handle_t im_memseg);
This function unmaps an imported segment from user virtual address space.
RSMERR_BAD_SEG_HNDL
