Programming Interfaces Guide
rsm_get_controller_attr
int rsm_get_controller_attr(rsmapi_controller_handle_t chdl, rsmapi_controller_attr_t *attr);
This function retrieves attributes for the specified controller handle. The following list describes the currently defined attributes for this function:
typedef struct {
     uint_t       attr_direct_access_sizes;
     uint_t       attr_atomic_sizes;
     size_t       attr_page_size;
     size_t       attr_max_export_segment_size;
     size_t       attr_tot_export_segment_size;
     ulong_t      attr_max_export_segments;
     size_t       attr_max_import_map_size;
     size_t       attr_tot_import_map_size;
     ulong_t      attr_max_import_segments;
 } rsmapi_controller_attr_t;
Return Values: Returns 0 if successful. Returns an error value otherwise.
RSMERR_BAD_CTLR_HNDL
Invalid controller handle
RSMERR_BAD_ADDR
Bad address
