Programming Interfaces Guide
sctp_getpaddrs()
The sctp_getpaddrs() function returns all peer addresses in an association.
int sctp_getpaddrs(int sock, sctp_assoc_t id, void **addrs);
When the sctp_getpaddrs() function returns successfully, the value of the **addrs parameter points to a dynamically allocated packed array of sockaddr structures of the appropriate type for each address. The calling thread frees the memory with the sctp_freepaddrs() function. The **addrs parameter cannot have a value of NULL. If the socket descriptor given in sock is for an IPv4 socket, the sctp_getpaddrs() function returns IPv4 addresses. If the socket descriptor given in sock is for an IPv6 socket, the sctp_getpaddrs() function returns a mix of IPv4 and IPv6 addresses. For one-to-many style sockets, the id parameter specifies the association to query. The sctp_getpaddrs() function ignores the id parameter for one-to-one style sockets. When the sctp_getpaddrs() function returns successfully, it returns the number of peer addresses in the association. If there is no association on this socket, the sctp_getpaddrs() function returns 0 and the value of the **addrs parameter is undefined. If an error occurs, the sctp_getpaddrs() function returns -1 and the value of the **addrs parameter is undefined.
If the file descriptor passed to the sctp_getpaddrs() function in the sock parameter is invalid, the sctp_getpaddrs() function fails and returns EBADF. If the file descriptor passed to the sctp_getpaddrs() function in the sock parameter does not describe a socket, the sctp_getpaddrs() function fails and returns ENOTSOCK. If the file descriptor passed to the sctp_getpaddrs() function in the sock parameter describes a socket that is not connected, the sctp_getpaddrs() function fails and returns ENOTCONN.
