Programming Interfaces Guide
Controlling a Shared Memory Segment
shmctl(2) is used to alter the permissions and other characteristics of a shared memory segment. The cmd argument is one of following control commands.
SHM_LOCK
Lock the specified shared memory segment in memory. The process must have the effective ID of superuser to perform this command.
SHM_UNLOCK
Unlock the shared memory segment. The process must have the effective ID of superuser to perform this command.
IPC_STAT
Return the status information contained in the control structure and place it in the buffer pointed to by buf. The process must have read permission on the segment to perform this command.
IPC_SET
Set the effective user and group identification and access permissions. The process must have an effective ID of owner, creator or superuser to perform this command.
IPC_RMID
Remove the shared memory segment. The process must have an effective ID of owner, creator, or superuser to perform this command.
The following code illustrates shmctl(2).
#include                     <sys/types.h>
#include                     <sys/ipc.h>
#include                     <sys/shm.h>
int     cmd;                 /* command code for shmctl() */
int     shmid;               /* segment ID */
struct  shmid_ds  shmid_ds;  /* shared memory data structure to hold results */
        shmid = ...
        cmd = ...
        if ((rtrn = shmctl(shmid, cmd, shmid_ds)) == –1) {
                perror("shmctl: shmctl failed");
                exit(1);
