System Administration Guide: Devices and File Systems
Choosing the Type of Backup
You can perform full or incremental backups by using the ufsdump command. You can create a temporary image of a file system by using the fssnap command. The following table lists the differences between these types of backup procedures.
Table 23–4 Differences Between Types of Backups
Backup Type
Copies a complete file system or directory
All data is in one place
Requires large numbers of backup tapes that take a long time to write. Takes longer to retrieve individual files because the drive has to move sequentially to the point on the tape where the file is located. You might have to search multiple tapes.
Creates a temporary image of a file system
System can be in multiuser mode
System performance might degrade while the snapshot is created.
Copies only those files in the specified file system that have changed since a previous backup
Easier to retrieve small changes in file systems
Finding which incremental tape contains a file can take time. You might have to go back to the last full backup.
