System Administration Guide: Devices and File Systems
Specifying ufsdump Command Options and Arguments
This section describes how to specify options and arguments for the ufsdump command. The syntax for the ufsdump command is as follows:
/usr/sbin/ufsdump options arguments filenames
options
Is a single string of one-letter option names.
arguments
Identifies option arguments and might consist of multiple strings. The option letters and their associated arguments must be in the same order.
filenames
Identifies the files to back up. These arguments must always come last, each separated by a space.
Default ufsdump Options
If you run the ufsdump command without any options, use this syntax:
# ufsdump filenames
The ufsdump command uses these options and arguments, by default:
ufsdump 9uf /dev/rmt/0 filenames
These options do a level 9 incremental backup to the default tape drive at its preferred density.
For a description of the ufsdump options, see ufsdump(1M).
