System Administration Guide: Devices and File Systems
Determining the Type of Tape Device You Need
You must use a tape device that is compatible with the backup media to restore the files. The format of the backup media determines which drive you must use to restore files. For example, if your backup media is 8-mm tape, you must use an 8-mm tape device to restore the files.
