System Administration Guide: Devices and File Systems
ProcedureHow to Retrieve Files From a Diskette (tar)
  1. Change to the directory where you want to put the files.
  2. Insert the diskette into the drive.
  3. Make the diskette available.
    $ volcheck
  4. Retrieve files from the diskette.
    $ tar xvf /vol/dev/aliases/floppy0
    All files on the diskette are copied to the current directory.
  5. Verify that the files have been retrieved.
    $ ls -l
  6. Remove the diskette from the drive.
Example 28–16 Retrieving Files From a Diskette (tar)
The following example shows how to retrieve all the files from a diskette.
$ cd /home/smith/Evaluations
$ volcheck
x evaluation.doc, 44032 bytes, 86 tape blocks
x evaluation.doc.backup, 43008 bytes, 84 tape blocks
$ ls -l
The following example shows how to retrieve an individual file from a diskette. The file is extracted from the diskette and placed in the current working directory.
$ volcheck
$ tar xvf /vol/dev/aliases/floppy0 evaluation.doc
$ ls -l
