System Administration Guide: Devices and File Systems
ProcedureHow to Extract Files From a Remote Tape Device
  1. Insert the tape into the tape drive.
  2. Change to a temporary directory.
    $ cd /var/tmp
  3. Extract the files from a remote tape device.
    $ rsh remote-host dd if=/dev/rmt/n | tar xvBpf -
    rsh remote-host
    Indicates a remote shell that is started to extract the files from the tape device by using the dd command.
    dd if=/dev/rmt/n
    Indicates the input device.
    | tar xvBpf -
    Pipes the output of the dd command to the tar command, which is used to restore the files.
  4. Verify that the files have been extracted.
    $ ls -l
Example 28–13 Extracting Files From a Remote Tape Drive
$ cd /var/tmp
$ rsh mercury dd if=/dev/rmt/0 | tar xvBpf -
x answers/, 0 bytes, 0 tape blocks
x answers/test129, 48 bytes, 1 tape blocks
20+0 records in
20+0 records out
x sc.directives/, 0 bytes, 0 tape blocks
x sc.directives/sc.190089, 77 bytes, 1 tape blocks
x tests/, 0 bytes, 0 tape blocks
x tests/test131, 84 bytes, 1 tape blocks
$ ls -l
