System Administration Guide: Devices and File Systems
Chapter 5 Managing Devices (Overview/Tasks)
This chapter provides overview information and step-by-step instructions for managing peripheral devices, such as disks, DVD drives, and tape devices, in the Solaris release.
This is a list of the overview information in this chapter.
This is a list of the step-by-step instructions in this chapter.
Device management in the Solaris release usually involves adding and removing peripheral devices from systems, possibly adding a third-party device driver to support a device, and displaying system configuration information.
What's New in Device Management?
This section provides information about new device management features in the Solaris release.
For a complete listing of new Solaris features and a description of Solaris releases, see Oracle Solaris 10 9/10 What’s New.
New Hot Plugging Features
Oracle Solaris 10 9/10: In this Solaris release, the hotplug command is available to manage hot pluggible connections on PCI Express (PCIe) and PCI SHPC (Standard Hot Plug Controller) devices. This feature is not supported on other bus types, such as USB and SCSI.
You would still use the cfgadm to manage hot pluggible USB and SCSI devices as in previous Solaris releases. The benefit of using the hotplug features in this release is that in addition to enable and disable operations, the hotplug command provides offline and online capabilities for your supported PCI devices.
For more information, see PCIe Hot-Plugging With the (hotplug) Command.
x86: Device Detection Tool
Solaris 10 5/08: You can use the device detection tool to identify whether your x86 hardware is supported in this Solaris release. For more information, go to the following site:
Support for PCI Express (PCIe)
Solaris 10 11/06: This Solaris release provides support for the PCI Express (PCIe) interconnect, which is designed to connect peripheral devices to desktop, enterprise, mobile, communication, and embedded applications, on both SPARC and x86 systems.
In the previous Solaris 10 6/06 release, PCIe devices were only available on x86 systems.
The PCIe interconnect is an industry-standard, high-performance, serial I/O bus. For details on PCIe technology, go to the following site:
The PCIe software provides the following features in this Solaris release:
The administrative model for hotplugging PCIe peripherals is the same as for PCI peripherals, which uses the cfgadm command.
Check your hardware platform guide to ensure that PCIe and PCIe hotplug support is provided on your system. In addition, carefully review the instructions for physically inserting or removing adapters on your system and the semantics of device auto-configuration, if applicable.
For information about using the cfgadm command with PCIe peripherals, see PCI or PCIe Hot-Plugging With the cfgadm Command (Task Map).
USB and 1394 (FireWire) Support Enhancements
Solaris 10 6/06: In this Solaris release, both non-removable USB storage devices and 1394 mass storage devices are identified as hotpluggable devices at the driver level. This new behavior means that these devices can be connected or disconnected without rebooting the system and configured or unconfigured automatically without intervention. These changes are made at the kernel level and do not impact the use of these devices. For example, the responsibility of mounting and unmounting these devices is controlled by the removable media management services.
In addition, non-removable USB devices and 1394 mass storage devices can be accessed and labeled by using the format utility. However, you can override the new hotpluggable behavior of these devices by setting the remvalue to true in the /kernel/drv/scsa2usb.conf file. Setting this parameter to true means that the device is treated as a removable media device at the driver level, if that behavior is preferred.
For more information on using these devices, see scsa1394(7D) and Using USB Mass Storage Devices (Task Map).
Improved Device In Use Error Checking
Solaris 10 6/06: This feature was undocumented previously.
The following utilities have been enhanced to detect when a specified device is in use:
These enhancements mean that the above utilities might detect some of the following usage scenarios:
For example, if you attempt to use the format utility to access an active device, you will see a message similar to the following:
# format
Specify disk (enter its number): 1
selecting c0t1d0
[disk formatted]
Warning: Current Disk has mounted partitions.
/dev/dsk/c0t1d0s0 is currently mounted on /. Please see umount(1M).
/dev/dsk/c0t1d0s1 is currently used by swap. Please see swap(1M).
However, these utilities do not detect all scenarios in the same way. For example, you can use the newfs command to create a new file system on a device in a live upgrade configuration. You cannot use the newfs command to create a new file system on a device that is part of a live upgrade configuration if it also has a mounted file system.
Where to Find Device Management Tasks
The following table describes where to find step-by-step instructions for hot-plugging devices and adding serial devices, such as printers and modems, and peripheral devices, such as a disk, DVD drive, or tape device.
Table 5–1 Where to Find Instructions for Adding a Device
For More Information
Add a disk that is not hot-pluggable.
Chapter 12, SPARC: Adding a Disk (Tasks) or Chapter 13, x86: Adding a Disk (Tasks)
Hot-plug a SCSI or PCI device.
SCSI Hot-Plugging With the cfgadm Command or PCI or PCIe Hot-Plugging With the cfgadm Command
Hot-plug a USB device.
Add a DVD drive or tape device.
How to Add a Peripheral Device
Add a modem.
Chapter 1, Managing Terminals and Modems (Overview), in System Administration Guide: Advanced Administration
Add a printer.
System Administration Guide: Printing
Secure a device.
Chapter 4, Controlling Access to Devices (Tasks), in System Administration Guide: Security Services
Managing Devices in the Solaris OS
The following sections provide overview information about features that manage devices in the Solaris OS. For information about accessing devices, see Accessing Devices.
Power Management of Devices
The United States Environmental Protection Agency created the Energy Star guidelines for computer products to encourage the use of energy-efficient computer systems and to reduce air pollution associated with energy generation. To meet these guidelines, Sun hardware is designed to use power efficiently. In addition, power management software is provided to configure the power management settings.
For more information about power managing your system, see your specific hardware documentation or power.conf(4).
Power Management of Fibre Channel Devices
Power management of Sun systems has been provided in many previous Solaris releases. For example, the internal drives on the following systems are power managed by default:
The default settings in the /etc/power.conf file ensure Energy Star compliance and fully support power management of these systems.
The following adapters connect external Fibre Channel storage devices:
If a combination of the above adapters and Sun systems are used to attach external Fibre Channel storage devices, the external storage devices will also be power managed by default.
Under the following conditions, power management should be disabled:
Power management should not be enabled when more than one Solaris system might share the same devices, as in the above conditions.
You can disable power management for the system by changing the autopm keyword in the /etc/power.conf file as follows:
autopm 		disable
Then, reconfigure power management by running the pmconfig command or by rebooting the system.
For more information, see power.conf(4) and pmconfig(1M).
About Device Drivers
A computer typically uses a wide range of peripheral devices and mass-storage devices. Your system, for example, probably has a disk drive, a keyboard and a mouse, and some kind of magnetic backup medium. Other commonly used devices include the following:
The Solaris software does not directly communicate with all these devices. Each type of device requires different data formats, protocols, and transmission rates.
A device driver is a low-level program that allows the operating system to communicate with a specific piece of hardware. The driver serves as the operating system's “interpreter” for that piece of hardware.
Automatic Configuration of Devices
The kernel consists of a small generic core with a platform-specific component and a set of modules. The kernel is configured automatically in the Solaris release.
A kernel module is a hardware or software component that is used to perform a specific task on the system. An example of a loadable kernel module is a device driver that is loaded when the device is accessed.
The platform-independent kernel is /kernel/genunix. The platform-specific component is /platform/`uname -m`/kernel/unix.
The kernel modules are described in the following table.
Table 5–2 Description of Solaris Kernel Modules
Directory Contents
Platform-specific kernel components
Kernel components common to all platforms that are needed for booting the system
Kernel components common to all platforms within a particular instruction set
The system determines what devices are attached to it at boot time. Then, the kernel configures itself dynamically, loading needed modules into memory. At this time, device drivers are loaded when devices, such as disk devices and tape devices, are accessed. This process is called autoconfiguration because all kernel modules are loaded automatically when they are needed.
You can customize the way in which kernel modules are loaded by modifying the /etc/system file. For instructions on modifying this file, see system(4).
Features and Benefits of Autoconfiguration
The benefits of autoconfiguration are as follows:
Autoconfiguration is used when you add a new device (and driver) to the system. At this time, you might need to perform reconfiguration boot so that the system recognizes the new device unless the device is hot-pluggable. For information about hot-plugging devices, see Chapter 6, Dynamically Configuring Devices (Tasks).
What You Need for Unsupported Devices
Device drivers needed to support a wide range of standard devices are included in the Solaris release. These drivers can be found in the /kernel/drv and /platform/`uname -m`/kernel/drv directories.
However, if you have purchased an unsupported device, the manufacturer should provide the software that is needed for the device to be properly installed, maintained, and administered.
At a minimum, this software includes a device driver and its associated configuration (.conf) file. The .conf files reside in the drv directories. This software might also include custom maintenance and administrative utilities because the device might be incompatible with Solaris utilities.
For more information about what you need for unsupported devices, contact your device manufacturer.
Displaying Device Configuration Information
Three commands are used to display system and device configuration information.
Man Page
Displays system configuration information, including the total amount of memory and the device configuration as described by the system's device hierarchy. The output displayed by this command depends upon the type of system.
Displays device configuration information, including system hardware, pseudo devices, loadable modules, and selected kernel parameters.
Displays system diagnostic messages as well as a list of devices attached to the system since the last reboot.
For information on the device names that are used to identify devices on the system, see Device Naming Conventions.
driver not attached Message
The following driver-related message might be displayed by the prtconf and sysdef commands:
device, instance #number (driver not attached)
This message does not always mean that a driver is unavailable for this device. This message means that no driver is currently attached to the device instance because no device exists at this node or the device is not in use. Drivers are loaded automatically when the device is accessed. They are unloaded when the device is not in use.
ProcedureHow to Display System Configuration Information
Use the output of the prtconf and sysdef commands to identify which disk, tape, and DVD devices are connected to the system. The output of these commands displays the driver not attached messages next to the device instances. Because these devices are always being monitored by some system process, the driver not attached message is usually a good indication that no device exists at that device instance.
Use the sysdef command to display system configuration information that include pseudo devices, loadable modules, and selected kernel parameters.
  1. Display system and device configuration information.
    • Display all the devices connected to a system.
      For example, the following prtconf -v output on a SunBlade 1000 identifies the disk devices connected to the system. The detailed disk information is described in the Device Minor Nodes section within the ssd/fp driver section.
      $ /usr/sbin/prtconf -v | more
                  Device Minor Nodes:
                            spectype=blk type=minor
                            spectype=chr type=minor
    • Display information about one specific device connected to the system.
      For example, the following prtconf output on a SunBlade 1000 displays the ssd instance number for /dev/dsk/c0t1d0s0.
      # prtconf -v /dev/dsk/c0t1d0s0
      ssd, instance #1
    • Display only the devices that are attached to the system.
      # prtconf | grep -v not
    • Display device usage information.
      For example, the following fuser command displays which processes are accessing the /dev/console device.
      # fuser -d /dev/console
      /dev/console:      346o     323o
Example 5–1 Displaying System Configuration Information
The following prtconf output is displayed on a SPARC based system.
# prtconf
System Configuration:  Sun Microsystems  sun4u
Memory size: 512 Megabytes
System Peripherals (Software Nodes):
    scsi_vhci, instance #0
    packages (driver not attached)
        SUNW,builtin-drivers (driver not attached)
        deblocker (driver not attached)
        disk-label (driver not attached)
        terminal-emulator (driver not attached)
        obp-tftp (driver not attached)
        dropins (driver not attached)
        kbd-translator (driver not attached)
        ufs-file-system (driver not attached)
    chosen (driver not attached)
    openprom (driver not attached)
        client-services (driver not attached)
    options, instance #0
    aliases (driver not attached)
    memory (driver not attached)
    virtual-memory (driver not attached)
    SUNW,UltraSPARC-III, instance #0
    memory-controller, instance #0
    SUNW,UltraSPARC-III, instance #1
    memory-controller, instance #1
    pci, instance #0
        ebus, instance #0
            flashprom (driver not attached)
            bbc (driver not attached)
            ppm, instance #0
            i2c, instance #0
                dimm-fru, instance #0
                dimm-fru, instance #1
                dimm-fru, instance #2
                dimm-fru, instance #3
                nvram, instance #4
                idprom (driver not attached)
            i2c, instance #1
                cpu-fru, instance #5
                temperature, instance #0
                cpu-fru, instance #6
                temperature, instance #1
                fan-control, instance #0
                motherboard-fru, instance #7
                i2c-bridge (driver not attached)
            beep, instance #0
            rtc, instance #0
            gpio (driver not attached)
            pmc (driver not attached)
            floppy (driver not attached)
            parallel (driver not attached)
            serial, instance #0
        network, instance #0
        firewire, instance #0
        usb, instance #0
        scsi (driver not attached)
            disk (driver not attached)
            tape (driver not attached)
    pci, instance #1
        SUNW,qlc, instance #0
            fp (driver not attached)
            fp, instance #1
                ssd, instance #1
                ssd, instance #0 (driver not attached)
                ssd, instance #2 (driver not attached)
                ssd, instance #3 (driver not attached)
                ssd, instance #4 (driver not attached)
                ssd, instance #5 (driver not attached)
                ssd, instance #6 (driver not attached)
    upa, instance #0
        SUNW,ffb, instance #0 (driver not attached)
    ppm, instance #0
    pseudo, instance #0
The following sysdef output is displayed from an x86 based system.
# sysdef
* Hostid
* i86pc Configuration
* Devices
+boot (driver not attached)
i86pc-memory (driver not attached)
i86pc-mmu (driver not attached)
delayed-writes (driver not attached)
itu-props (driver not attached)
isa, instance #0
	motherboard (driver not attached)
	pnpADP,1542, instance #0
	asy, instance #0
	asy, instance #1
	lp, instance #0 (driver not attached)
	fdc, instance #0
		fd, instance #0
		fd, instance #1 (driver not attached)
	kd (driver not attached)
	kdmouse (driver not attached)
Adding a Peripheral Device to a System
Adding a new peripheral device that is not-pluggable usually involves the following:
Use How to Add a Peripheral Device to add the following devices that are not hot-pluggable to a system:
In some cases, you might have to add a third-party device driver to support the new device.
For information on hot-plugging devices, see Chapter 6, Dynamically Configuring Devices (Tasks).
ProcedureHow to Add a Peripheral Device
  1. Become superuser.
  2. (Optional) If you need to add a device driver to support the device, complete the procedure How to Add a Device Driver.
  3. Create the /reconfigure file.
    # touch /reconfigure
    The /reconfigure file causes the Solaris software to check for the presence of any newly installed devices the next time you turn on or boot your system.
  4. Shut down the system.
    # shutdown -i0 -g30 -y
    Brings the system to the 0 init state, which is the appropriate state for turning the system power off for adding and removing devices.
    Shuts the system down in 30 seconds. The default is 60 seconds.
    Continues the system shutdown without user intervention. Otherwise, you are prompted to continue the shutdown process.
  5. Select one of the following to turn off power to the system after it is shut down:
    • For SPARC platforms, it is safe to turn off power if the ok prompt is displayed.
    • For x86 platforms, it is safe to turn off power if the type any key to continue prompt is displayed.
  6. Turn off power to all peripheral devices.
    For the location of power switches on any peripheral devices, refer to the hardware installation guides that accompany your peripheral devices.
  7. Install the peripheral device, making sure that the device you are adding has a different target number than the other devices on the system.
    Often, a small switch is located at the back of the disk for selecting the target number.
    Refer to the hardware installation guide that accompanies the peripheral device for information on installing and connecting the device.
  8. Turn on the power to the system.
    The system boots to multiuser mode, and the login prompt is displayed.
  9. Verify that the peripheral device has been added by attempting to access the device.
    For information on accessing the device, see Accessing Devices.
ProcedureHow to Add a Device Driver
This procedure assumes that the device has already been added to the system. If not, see What You Need for Unsupported Devices.
  2. Place the tape, diskette, or DVD into the drive.
  3. Install the driver.
    # pkgadd [-d] device package-name
    -d device
    Identifies the device path name that contains the package.
    Identifies the package name that contains the device driver.
  4. Verify that the package has been added correctly.
    # pkgchk package-name
    The system prompt returns with no response if the package is installed correctly.
Example 5–2 Adding a Device Driver
The following example shows how to install and verify a package called XYZdrv.
# pkgadd XYZdrv
(licensing messages displayed)
Installing XYZ Company driver as <XYZdrv>
Installation of <XYZdrv> was successful.
# pkgchk XYZdrv
Accessing Devices
You need to know how to specify device names when using commands to manage disks, file systems, and other devices. In most cases, you can use logical device names to represent devices that are connected to the system. Both logical and physical device names are represented on the system by logical and physical device files.
How Device Information Is Created
When a system is booted for the first time, a device hierarchy is created to represent all the devices connected to the system. The kernel uses the device hierarchy information to associate drivers with their appropriate devices. The kernel also provides a set of pointers to the drivers that perform specific operations.
How Devices Are Managed
The devfs file system manages the /devices directory, which is the name space of all devices on the system. This directory represents the physical devices that consists of actual bus and device addresses.
The dev file system manages the /dev directory, which is the name space of logical device names.
By default, the devfsadm command attempts to load every driver in the system and attach to all possible device instances. Then, devfsadm creates the device files in the /devices directory and the logical links in the /dev directory. The devfsadm command also maintains the path_to_inst instance database.
Updates to the /dev and /devices directories in response to dynamic reconfiguration events or file system accesses are handled by devfsadmd, the daemon version of the devfsadm command. This daemon is started by the service management facility when a system is booted.
Because the devfsadmd daemon automatically detects device configuration changes generated by any reconfiguration event, there is no need to run this command interactively.
For more information, see the following references:
Devices are referenced in three ways in the Oracle Solaris OS.
The preceding device name information is displayed with the following commands:
Logical Disk Device Names
Logical device names are used to access disk devices when you perform the following tasks:
Many administration commands take arguments that refer to a disk slice or file system.
Refer to a disk device by specifying the subdirectory to which it is symbolically linked, either /dev/dsk or /dev/rdsk, followed by a string identifying the particular controller, disk, and slice.
Figure 5–1 Description of Logical Device Names
Diagram of logical device name components: raw disk device
directory, logical controller, physical bus target, drive, and slice or fdisk
Specifying the Disk Subdirectory
Disk and file administration commands require the use of either a raw (or character) device interface, or a block device interface. The distinction is made by how data is read from the device.
Raw device interfaces transfer only small amounts of data at a time. Block device interfaces include a buffer from which large blocks of data are read at once.
Different commands require different interfaces:
The following table shows which interface is required for some commonly used disk and file system commands.
Table 5–3 Device Interface Type Required by Some Frequently Used Commands
Command Reference
Interface Type
Example of Use
df /dev/dsk/c0t3d0s6
fsck -p /dev/rdsk/c0t0d0s0
mount /dev/dsk/c1t0d0s7 /export/home
newfs /dev/rdsk/c0t0d1s1
prtvtoc /dev/rdsk/c0t0d0s2
Direct and Bus-Oriented Controllers
You might access disk partitions or slices differently depending upon whether the disk device is connected to a direct or bus-oriented controller. Generally, direct controllers do not include a target identifier in the logical device name.
The conventions for both types of controllers are explained in the following subsections.
Note –
Controller numbers are assigned automatically during system initialization. The numbers are strictly logical and imply no direct mapping to physical controllers.
x86: Disks With Direct Controllers
To specify a slice on a disk with an IDE controller on an x86 based system, follow the naming convention shown in the following figure.
Figure 5–2 x86: Disks With Direct Controllers
Diagram of device name for disks with direct controllers
that includes logical controller, drive, and slice or fdisk partition.
To indicate the entire Solaris fdisk partition, specify slice 2 (s2).
If you have only one controller on your system, w is usually 0.
Disks With Bus-Oriented Controllers
To specify a slice on a disk with a bus-oriented controller, SCSI for instance, follow the naming convention shown in the following figure.
Figure 5–3 Disks With Bus-Oriented Controllers
Device name for disks with bus-oriented controllers that
includes logical controller, physical bus target, drive, and slice or fdisk
On a SPARC based system with directly connected disks such as the IDE disks on an UltraSPARC system, the naming convention is the same as that for systems with bus-oriented controllers.
For SCSI controllers, x is the target address set by the switch on the back of the unit, and y is the logical unit number (LUN) of the drive attached to the target. If the disk has an embedded controller, y is usually 0. For more information about SCSI addressing on SPARC based systems, see the SunSolve Info Doc 48041 and scsi_address(9S).
To indicate the whole disk, specify slice 2 (s2).
Logical Tape Device Names
Logical tape device files are found in the /dev/rmt/* directory as symbolic links from the /devices directory.
Figure 5–4 Logical Tape Device Names
Diagram of logical tape device name that includes magnetic
tape device directory, drive, and the optional density values.
The first tape device connected to the system is 0 (/dev/rmt/0). Tape density values (l, m, h, c, and u) are described in Chapter 29, Managing Tape Drives (Tasks).
Logical Removable Media Device Names
Since removable media is managed by removable media management services, the logical device name is usually not used unless you want to mount the media manually.
The logical device name that represents the removable media devices on a system are described in Chapter 3, Accessing Removable Media (Tasks).
