Task |
Description |
For Instructions |
Display information about SCSI devices. |
Display information about SCSI controllers and devices. | |
Unconfigure a SCSI controller. |
Unconfigure a SCSI controller. | |
Configure a SCSI controller. |
Configure a SCSI controller that was previously unconfigured. | |
Configure a SCSI device. |
Configure a specific SCSI device. | |
Disconnect a SCSI controller. |
Disconnect a specific SCSI controller. | |
Connect a SCSI controller. |
Connect a specific SCSI controller that was previously disconnected. | |
Add a SCSI device to a SCSI bus. |
Add a specific SCSI device to a SCSI bus. | |
Replace an identical device on a SCSI controller. |
Replace a device on the SCSI bus with another device of the same type. |
SPARC: How to Replace an Identical Device on a SCSI Controller |
Remove a SCSI device. |
Remove a SCSI device from the system. | |
Troubleshoot SCSI configuration problems. |
Resolve a failed SCSI unconfigure operation. |
